Electronics Hot Resistors
Discussion in 'Modding' started by jamicon, 17 Feb 2002.
  1. jamicon
    jamicon What's a Dremel?
    26 Nov 2001
    i built a LED array for my keyboard to make it glow, it all works fine, but the resistor i am using (27 Ohms, 2 watt) seems to get overly hot, as in within 3 seconds of plugging the ciruit up, it gets so hot that i cant even touch it. Is this ok, or does something need to be changed ?
  2. batsman
    batsman the quiet one
    14 Nov 2001
    your led's i take it they are wired to the keyboard power supply. the power disapted by the resistor should be about .9W which is with in's range. Resistors do get hot, so just make sure its not near to anything that can be easily damaged.
    Personaly i would put a higher wattage resistor in.
    what are your LED wired into?
  3. jamicon
    26 Nov 2001
    no, its connected to my pc 12v rail
    the resistor is a 2 watt resistor
    12v    Gnd
    each led is 1.8v and 20mA
    so 3x 1.8 =5.4
    20x13 =260
    12-5.4 = 6.6
    R = v / i
    r = 6.6 / 0.26
    r = 25 Ohms
    5.4 x .26 = watts
    1.404 = watts
    resistor i got, 27 ohms, 2 watt
    so why is this resistor getting so hot?, and should i put a ramsink on it to cool it down
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    1.5 watts on a small object = hot.
    You can knock the temperature down by using say four 110R (or 120R) in parallel, or lower the led current to 10-15mA, or use 6 strings of 4 leds, leaving less voltage to lose.
    I'd be tempted to split your array into several sections, each with it's own dropper resistor - avoids "current-stealing" by any of the strings.
    <bi-centeniall post :D
  5. macroman
    macroman The One
    3 Sep 2001
    Congratulations :cool:
  6. Sgt. Gimp
    Sgt. Gimp What's a Dremel?
    11 Nov 2001
    Actually thats the power used by the LED array (1.8v * 3=5.4v), the voltage dropped by the resistor is 6.6v, so the power used by the resistor is 6.6 * 0.26=1.716W. This is getting a bit too close to the power rating of the resistor.
  7. jamicon
    26 Nov 2001
    what if i put a heatsink on the resistor using a little bit of Arctic silver epoxy? cuse i got a small heatsink (its actually a ramsink) and i got the epoxy already from previous projects
    would this do?
  8. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    dont know it might work the 50 watt ones from rapid go upto 100 watt if u put a specially made sink on them so might be worth giving it a go
    does arctic silver epoxy conduct?
  9. macroman
    macroman The One
    3 Sep 2001
    If you don't want to spread the load using several resistors then just replace it with a 5Watt version and have done. :)
  10. batsman
    14 Nov 2001
    its connected to a 12 v power supply, the resistor is going to have a potential difference of about 12v. which means the power disapated is going to be 5.3W.
    power dissapted in a resistor = v squared x r
  11. macroman
    macroman The One
    3 Sep 2001
    Actually the PD is 6.6V
  12. batsman
    14 Nov 2001
    yeah fair enough, didn't ead that far originaly. opps
  13. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Try V^2/R
  14. batsman
    14 Nov 2001
    typing error.
    god i'm being a total spaz i know its v^2 /R and I^2 * R, i just typed it wrong. otherwise i would have said the wattage was like 1176.12 W using v^2 * R where v = 6.6 and r = 27. and not many people have 1000W Psu's (yet)
