Modding Hotmods.net review #1: Bitfenic "Alchemy" series S-ATA cable
Discussion in 'Modding' started by Nutman, 17 Jun 2011.
  1. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    OCTeamdenmark have sent me some pre-sleeved S-ATA cables from Bitfenix's "Alchemy" series for reviewing and I can already tell you that I'm quite exited about these cables.
    The sleeving sits nice and tight on these cables and it's a soft kind of sleeving, secured without using heatshrink, but kind of melted into the plug at both ends of the cable. This is what sets these cables apart from other pre-sleeved cables, such as the ones coming from NZXT, for example (which are sleeved quite badly, in my opinion). All other cables from Bitfenix's "Alchemy" series are sleeved without using heatshrink - except for the fan extension cables. I think these cables are very cool and Bitfenix certainly leaves the competition pretty far behind.
    The cables are available in many colours, so you will be able to choose the colour that fits the theme of your case. As far as I know you can only get them in a specific length - perhaps that's something Bitfenix should be thinking about changing?
    Ok, but a says more than a thousand words, here are 2975x1000 words for you:
