How about a favicon?
Discussion in 'Feedback & Suggestions' started by cpemma, 22 Feb 2002.
  1. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I find they help pick out my frequently-visited sites like Bit-Tech and Kara.
    You could make it a competition. ;)
  2. RTT
    RTT #parp
    12 Mar 2001
    favicon? :confused:
    expand a little ;)
  3. linear
    linear Minimodder
    5 Oct 2001
    IE 4 and later will allow you to use an icon to represent your site in the bookmarks or favorites or whatever the hell IE calls the sites you like. You store it in the document root as favicon.ico and it gets pulled by IE automagically.
    for example http://linear1.org/ has one. Or Google.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    If you put a 32x32 (or 16x16) .ico file called favicon.ico in the site root folder, anybody (with IE4+) bookmarking the site gets it alongside the site name in Favorites.
    Or you can point to it with a line in the <head> code:
    <link rel="SHORTCUT ICON" href="http://www.cpemma.fsnet.co.uk/fan.ico">
    The icon also appears in the IE url window instead of the default IE one, if bookmarked.
    Example at http://www.cpemma.fsnet.co.uk ;)
    Giving:
    (Linear - you could use transparency on yours :p )
  5. linear
    linear Minimodder
    5 Oct 2001
    IE is such krap. Yours doesn't show up for me in IE6 under XP or 98, and mine doesn't show up for me under IE6 under 98 but does on IE5.5 on 98.... *sigh*
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    No problem IE6/98SE
    Odd-ball thing is that favicon only shows in the address window if you click from the Favorites link AFAIK.
    And they only last whils't the file is cached, so any I like I extract from the cache to a permanent folder and "change icon" for the link shortcut.
    I luv IE :D
    Needs more work on it. :eek:
  7. linear
    linear Minimodder
    5 Oct 2001
    I was just fooling with mine today, for reasons unrelated to this post--if you have an old one cached, I'm pretty sure the current one has transparency.
  8. pszaro
    pszaro What's a Dremel?
    11 Mar 2002
  9. Cuzza
    Cuzza What's a Dremel?
    14 Apr 2010
    Hey bit-tech peeps. Resurrecting this favicon thread because I can't get the bit-tech favicon to appear in Firefox 4. It works for me in other browsers. Is it just me?
    Anyway I really like having a bit-tech icon in my toolbar to if this could be fixed I'll be stoked.
    Cuzza
  10. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    Holy thread necro....
    I use FF4 on multiple computers, it works fine. If you just added it to your bookmark bar you will need to click it once and it should appear.
  11. Cuzza
    14 Apr 2010
    no such luck I'm afraid. all of my other bookmarks appear there as normal, but bit-tech fails!
  12. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Works fine on FF4 here.
  13. stonedsurd
    11 Mar 2009
    Workin' fine on FF4 here as well.
  14. Cuzza
    14 Apr 2010
    I suppose I should have done this in the first place, I reinstalled FF4 and now it works. Weird.... ah well, thanks for your replies!
