Blogs How are you getting on with Bing?
Discussion in 'Article Discussion' started by CardJoe, 22 Oct 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. GFC
    GFC What's a Dremel?
    7 Nov 2008
    When it came out I tried it a couple of times. But to be honest, even if bing is better (which I'm not convinced yet) I'll still be using google just because I'm so used to it.
  3. stonedsurd
    11 Mar 2009
    Same as GFC.
    I'm just too used to google.
    I did obsessively double-search on bing and google to compare results something like 2 months ago, but even then google gave me what I needed quicker and better.
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    After installing Windows 7 the other day and using IE8 which defaults to Bing search I had my first genuine experience with it. Bing failed to give me what I was looking for so I headed over to google and got exactly what I wanted in the first few results.
    Bing still isn't good enough for me.
  5. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    As I conveyed in the ad-like Bit-tech logoed survey, it's okay, but not a substitute for google. I've noticed that a lot of sites are now featuring "look this up on Bing" links.
    Bing can throw all the money they want at trying to get people to come over, but if it will succeed, it will take time.
    I use Bing cashback, and have used them for brief product shopping, and find it ever so slightly better than google's product search.
    What I still don't get is how Bing is a "decision engine."
  6. Veles
    Veles DUR HUR
    18 Nov 2005
    Bing?
  7. Digibull
    Digibull Stealth Geek
    19 Jul 2009
    I find that both come up with such varied results I tend to use both. I work as an IT support rep who is the main contact for roughly 200 users across Europe and sadly I can't answer every query off the top of my head so I do turn to a search engine on a regular basis. With the same string both will give me different hits.
    What I would say its the best comparason between the two (and I highly recommend this is searched out of work, behind closed doors and the other half bribed out of the house with a tenner for a bottle of wine (yes i am cheap date)) is to type in 'porn'. Google will bring up a list of all the free porn streaming sites... Bing will give you definitions and wikipedia.
    Also a good URL for comparason: http://www.bing-vs-google.com/
  8. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    But It's Not Google
    used it once or twice, but as my search engine tends to default to google guess what tends to get used...
  9. Xir
    Xir Modder
    26 Apr 2006
    ...well Bing is "familiy filtered" isn't it?
    which is a reason not to use it ;-)
    Other than that? Meh, has no pluspoints over google really.
    And yes, that "survey" really was more an ad than a survey, wasn't it? No criticism allowed in this survey.
  10. Stuey
    20 Jan 2005
    The "survey" popped up again. What the heck?
    imho, I'm becoming even more less inclined to use Bing the more I see it advertised.
    Why is google so ubiquitous? Ease of use, and a solid reputation.
  11. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Am I the only one who googled Bing to find it?
  12. ffjason
    ffjason What's a Dremel?
    27 Jul 2009
    I still find that it doesn't give me the results I want, where as google is much more accurate. I can also navigate google easily where as bing just looks cluttered.
  13. Cutter McJ1b
    Cutter McJ1b Home-cut jibs at discount Prices
    18 Feb 2009
    I lol'ed
  14. Tim S
    Tim S OG
    8 Nov 2001
    :D
  15. bradders2125
    bradders2125 What's a Dremel?
    14 Jul 2008
    I used to use live search religiously but moved to google. Tried bing but google is my default search engine.
  16. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Google has never left me dissapointed, I will continue to use Google.
  17. thefriscokid
    thefriscokid why s**t so crazy?
    30 Aug 2005
    What is Bing again?
  18. Furymouse
    Furymouse Like connect 4 in dagger terms
    4 Feb 2004
    I use Bing at work as Google is blocked by our OpenDNS. I honestly don't see much difference between the two and me sticking with Google at home is more than likely down to pure habit.
  19. AngusW
    AngusW mmm
    20 Oct 2009
    Well its more or less instinct now to type in www.google.com when i want to search something so i can't see me changing that very easily. Plus googles better imo
  20. D-Cyph3r
    D-Cyph3r Gay for Yunosuke
    31 Aug 2008
    QFT
Tags: Add Tags
