Modding How can i add my case a door ?
Discussion in 'Modding' started by Eran, 12 Nov 2004.
  1. Eran
    Eran What's a Dremel?
    6 Nov 2004
    a simple door like enermaxe's cases doors.... :dremel: :dremel:
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
    buy an enermax? :D
  3. Eran
    6 Nov 2004
    but i wanna use a compucase lying case... :sigh:
  4. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    Simple hinges and a snape in lock. Lay in the hinges(cut plastic below them so that are evenwith case) then bondo over them and you will have a hiddin door hinge attcched to a door.
  5. Eran
    6 Nov 2004
    Can you be please more specific ? i didn't really understand :p
  6. Mr.Nonflex
    Mr.Nonflex What's a Dremel?
    2 Jun 2004
    Could you post a picture of your case, or a sketch of your idea, that would give us something to work with.
  7. infered101
    30 Oct 2004
    Yes post a pic of the side panel and will show you what i mean.
