How can i clock higher?
Discussion in 'Hardware' started by Hazza, 16 May 2005.
  1. Hazza
    Hazza New Member
    25 Nov 2003
    Hey all.
    Im running an Athlon64 3500+ Winchester with a nice big thermalright XP120 on it, iv got an Abit AV8 3rd eye and 2*256MB Geil PC3500 CL2 RAM. I have no problem overclocking a bit (to 2500MHz or so) but then things just seem to fall apart and I cant seem to get round this :wallbash:
    The best i can get is 232*11 bus @ 1.6V. RAM at 2.7V NB at 1.55V HyperTransport at 1.25V SB at 2.5V. AGP/PCI bus locked at 66/33 MHz.
    Iv got a lot of mileage in my voltages and things dont run that hot at these settings, but I just can't seem to get anything to run stably for more than about 2 mins at these settings. I know 232 FSB is more than my RAM is rated for, but iv dropped the latencies and it seems to do fine, as far as i know.
    So, any ideas?
  2. 2800@2.5ghz
    2800@2.5ghz New Member
    23 Mar 2005
    more voltage????
  3. Hazza
    Hazza New Member
    25 Nov 2003
    iv tried putting some voltages up but it didnt make any difference :S
    the prob is i dont know which voltages are likely make it work.
    tis a bugger not being able to raise the multiplier :grr:
  4. fartonmyear
    fartonmyear New Member
    16 Jul 2004
    blow on it
  5. Blackfish23
    Blackfish23 Member
    13 Oct 2004
    Very helpful :grr:
  6. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    That is a bit of a hint you know; what kind of cooling solution do you have on it?
  7. mime genocide
    mime genocide New Member
    2 Sep 2004
    what are your temps idle/load
  8. Hazza
    Hazza New Member
    25 Nov 2003
    as said, got a thermalright xp120 with a YS-Tech 120mm fan on it. 2x80mm, 1x92mm fans exhaust and 2x80mm, 1x92mm fans intake.
  9. Hazza
    Hazza New Member
    25 Nov 2003
    IDLE:
    cpu: 25C (31C oc'd)
    nb: 26C (26C oc'd)
    pwm: 28C (32C oc'd)
    LOAD:
    cpu: 37C (47C oc'd)
    nb: 26C (26C oc'd)
    pwm: 31C (33C oc'd)
    these dont seem too hot to me (my old AXP 2000+ ran waay hotter and was stable)
  10. striker289
    striker289 New Member
    22 Jan 2005
    temps arent high. if you can bump your core volts up more maybe?it could be that your set up is unable to clock more.
  11. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    people read the posts. alrady stated
  12. Go4t
    Go4t i
    13 Dec 2003
    did you ever think that maybe thats just the highest it can go?
  13. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    That ain't modding spirit :naughty: It can ALWAYS go higher! :naughty:
  14. Hazza
    Hazza New Member
    25 Nov 2003
    ok, well iv managed to get 2.6GHz.
    I lowered the multiplier to 10.5 and used 248MHz FSB.
    I had my RAM timings looow and my CPU voltage about 1.7V :worried: RAM voltage at 2.8V (maximum) and hypertransport at 1.3V
    This worked long enough for me to run SuperPi, and it worked! unfortunately, as I finished the test in record time, it crashed :waah:
    I tried these same voltages with normal multiplier for 2.5GHz and it's still just as unstable. Maybe just the RAM cant take it? Its only rated for 217MHz@CAS2 so maybe 232MHz or so is a bit too far, even at CAS3.
  15. TMM
    TMM Modder
    12 Jan 2004
    Stick your ram on a [166] divider (theres no performance hit using a divider on A64s) and change the multi to 10. Work your way up from 250htt. At 250htt your mem should be at 200mhz, so atleast its not slower then @ stock.
    When you start to get unstable, and more CPU voltage doesn't help (Give your ram some more voltage and play with timings to make sure it not your ram thats being limited), then try going for a lower multi and higher HTT to obtain faster memory speeds.
    1.7v is a bit much for extended use. I'd recommend staying strictly under 1.65v on air, with load temperatures under 50*c.
  16. Hazza
    Hazza New Member
    25 Nov 2003
    Nice one, I'm liking that idea. Ill have a go tonight an report back :thumb:
    EDIT:
    Right, I had a go. Some success, but not much. Under those settings my RAM seems fine, but things are still very unstable. Setting the FSB to 250 or over crashes the pc instantly (from windows) or stops it booting (from bios). Between 2.5 and 2.6 GHz I get about 30 seconds of operation before either my whole screen freezes, or things freeze but my mouse still moves :sigh:
    With 10.5 multiplier i got the furthest, but it still didn't last long.
    When poking around in the bios i found LDT multiplier. is this to do with hypertransport? like FSB*LDT multiplier = hypertransport speed ?? if so, is it worth dropping the LDT from 5x to 4x to see if this makes things more stable?
    Dunno about anyone else's experience, but im wondering if the K8T800 Pro just isnt that good an overclocker. Either that or i expected too much :naughty:
  17. TMM
    TMM Modder
    12 Jan 2004
    ah forgot about the LDT :blush:
    yea set that to 3x. .. or 4x if you can get that stable, but theres no performance difference anyway.
  18. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    i've got the same mobo and processor as u, just with a GB of ram(look in sig), use the uGuru software to push it.
  19. Hazza
    Hazza New Member
    25 Nov 2003
    yea i do use the uGuru stuff, but some stuff you can only change in the bios.
    I'll have a go changing the LDT and report back :thumb:
  20. Hazza
    Hazza New Member
    25 Nov 2003
    weyhey! LDT solved all stability problems! Seems the AV8 just doesnt like the hypertransport running above 1150MHz or so. I can now hit 2.7GHz with ease, and much lower voltages :naughty:
    Thanks all (and esp TMM), any help was much appreciated :thumb:
