Disaster how can i fix this
Discussion in 'Modding' started by mind-goes-blank, 13 Jul 2004.
  1. mind-goes-blank
    mind-goes-blank What's a Dremel?
    20 Jun 2004
    i'm pretty new to modding. so of course the first things i did were buy some looming for the mess of wires i have and picked up a cold cathode but when i was installing the cathode i was unplugging onr of the wires that goes into the inverter (i think that's what it's called) anyways one of the wires ripped right out of the little plasitc conecter :wallbash: . so i stripped the wire and shoved it back in there but it doesn't stay there very well... if for example i move my computr or anything it falls out. how can i get the wire back in the connecter the way it's supposed to be?
  2. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
    in the plug, there is a gold/copper tube, take some tweezers pull it out, put the wire back in, secure it byclamping it a lil bit... thats how i did it
  3. k3nn
    k3nn What's a Dremel?
    2 Feb 2004
    duct tape?
  4. Goldfish
    Goldfish What's a Dremel?
    4 Jul 2004
    Is it possible to open the connector up and solder it back in there?
  5. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    It won't be soldered, although you could probably use some solder to fix it back in place properly.
    To get the tube out of the connector, try pushing a tiny screwdriver into the end and moving it around until you feel a little "tab", then push down on it and the tube should just slide straight out.
    Then it's just a case of opening the tube up, clamping the wire back in, and using a bit of solder to make sure it stays there :)
    Sorry if I didn't explain that very well, if you need any more details just ask me.
  6. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Superglue, Duck Tape or Solder it back in, or you could use my old standby - blutack! (Blutack is holding my GeForce 2 in ATM)
  7. Firehed
    15 Feb 2004
    Come on guys, it's duct tape. Duck is actually a brand of Duct tape. I'd know - I live in a place where we use it to hold our cars together.
  8. mind-goes-blank
    20 Jun 2004
    yea i can see the little tube in there. now i just need to find some tweezers.
  9. Goldfish
    4 Jul 2004
    Pliers work better for that :)
  10. mind-goes-blank
    20 Jun 2004
    thanks. for the help. i managaged to get in working again. though i did a TERRIABLE soldering job. seeing as it was only my second time. :D
  11. Firehed
    15 Feb 2004
    Well make sure you put heatshrink or at least electrical tape over it.
  12. LabRat1
    LabRat1 What's a Dremel?
    23 Jun 2004
    no way it could be worse that my fiends connectios he had some super overpowerd iron
    it vaporized the traces on the circuitboard :D
    if it works you did a good job
  13. cogitoergosum
    cogitoergosum What's a Dremel?
    14 Jul 2004
    hey, never diss your own soldering jobs. I'm sure we've all seen (and done) worse.
    And I stress again the need to insulate it. Electrical tape should work okay.
  14. mind-goes-blank
    20 Jun 2004
    yea that's excatly what i did. just wrapped it witha few pieces of eletrical tape.
  15. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    stick it back in the connector and fill the back with hot glue, that way it cant come loose again. Always works like a charm.
