How can i make COD 2 work under vista?
Discussion in 'Tech Support' started by eUphoria, 14 Sep 2007.
  1. eUphoria
    eUphoria What's a Dremel?
    9 Apr 2004
    As in the title really - i went to play this game and vista said NO! Anyone know if there is a work around for this? Thanks!
  2. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    As with a lot of games, if you haven't already tried right-click on your short cut, set it to XP Service Pack 2 Computability mode and set it to run with admin privs.
    If that doesn't work, try checking the official COD2 site/forums :)
  3. cannon
    cannon What's a Dremel?
    15 Jan 2004
    Have you patched the game to 1.2 i think it is?
    It works fine for me without changing the shortcut properties.
  4. knuck
    knuck Hate your face
    25 Jan 2002
    the game is now at 1.3
  5. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    Works fine for me on vista64
    To install, just browse the disk and run the setup exe instead of the autorun. Then, after its installed get the 1.3 update. Single player now works fine, then to make multiplayer load properly just go to the shortcut properties and check compatibility mode for windows XP.
  6. mattthegamer463
    26 Nov 2004
    Works fine for me on Vista Ult 32, however Punkbuster has recently started crapping itself every time I join a server.
