Modding How can i power a 2nd PSU??
Discussion in 'Modding' started by BMW XTC niL, 6 Feb 2002.
  1. BMW XTC niL
    BMW XTC niL What's a Dremel?
    6 Feb 2002
    HELP!! i want to put a 2nd power suply unit in my case, but i have noooo clue on how to turn it on. do i have to wire a switch?? :confused: :confused:
  2. Slink
    Slink B7
    7 Oct 2001
    If its an ATX case,
    Find the green wire, and add it to a switch with any black,
    Job done matey
  3. BMW XTC niL
    6 Feb 2002
    Like this???
    take green wire and put to black wire on molex??
  4. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    no! one of the blacks on the mobo plug. wire up a switch on the wire that linking the 2 so you can turn it on and off.
  5. BMW XTC niL
    6 Feb 2002
    ok ok
    ok ok so take the GReen wire which i pointed the arrow to and wire it to a black wire from the mobo with a switch?
  6. Slink
    Slink B7
    7 Oct 2001
    The big bundle of wires that goes into your mobo, Take the green, and one black from that bundle, and wire them to a switch,
    Stand well back and plug it in
  7. Tim S
    Tim S OG
    8 Nov 2001
    why not just get one of these from ****
    Makes the job a hell of a lot easier, and no need to hack up any power cables
    heres a pic
  8. BMW XTC niL
    6 Feb 2002
    thanks guys i got it to work. that multiple psu thingy looks cool, maybe i will get one but i'm in the USA. :(
  9. Tim S
    Tim S OG
    8 Nov 2001
    sure they must sell em somewhere over there, try some of the better overclocking shops :D
  10. bajastx
    bajastx What's a Dremel?
    22 Jan 2002
    OC Shops?!?!?:eek: Right, like we have those over here.:(
  11. Tim S
    Tim S OG
    8 Nov 2001
    Youve gotta be joking, there must be some overclocking stores out there :confused:
  12. Zmaster2k
    Zmaster2k You looking at me?
    15 Oct 2001
    who wants to start a business??
  13. tk421
    tk421 Idiot.
    15 Jan 2002
    the u.s. is way too warranty dependant for a oc store to do well enuff to be worth the trouble .... thats why we all depend on hardware/ home improvement places for everything
  14. Coords666
    Coords666 What's a Dremel?
    31 Dec 2001
    Is anyone else seeing a picture of a soundcard instead of the PSU in BMW XTC niL's post?
  15. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    The problem with ATX PSU's is they have to be connected to the mobo to power on. There are some work arounds. Basically, you can do it by jumpering pins on the ATX connector. I have seen people also throw in a switch in the jumper wire so you can control PSU from the front panel. I thought about doing this because I was going to use a dedicated PSU for non component items like lights etc... here are some articles:
    http://www.burningissues.net/how_to/power/psu.htm
    http://www.ocshoot.com/atxtweak.htm
    :cool:
  16. eddie_dane
    31 Jan 2002
  17. Wizard Sleeve
    Wizard Sleeve What's a Dremel?
    17 Dec 2003
    Hi All (My First Post)
    Im building a media server and eventually plan to have 20 250 gb sata drives in it but im gona add them as needed ( Not Raid )
    Now im gona get three 480w psus and plan to connect them so they all come on together by using realys powered off a molex, im acually gona build a power control box in ther server with a molex input and two plugs thatll take the atx motherboard connectors incase they need to be changed quickly and easily.
    My question is people have told me that switching psu need load on all the lines of the psu now this isnt a prob for the 12v and 5v lines but as i can see the 3.3v line is only used by the mobo so do i need to put false load on this line. Or in the way i see it does the psu just need load on it no matter what lines are loaded as long as there is some load.
    Thanks for the help. :D :D
  18. clocker
    clocker Shovel Ready
    21 Dec 2003
    I have wired three dual PSU rigs and never put a dummy load in any of 'em.
    Your results may vary....
  19. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    I've wired two PSUs in my server but I've only loaded the 5/12V lines. I agree with clocker!
  20. snifta
    snifta Guest
