Electronics How can I tap into the PSU when the pc is off??
Discussion in 'Modding' started by curme, 9 Jan 2004.
  1. curme
    curme Minimodder
    12 Sep 2002
    I know that there is still power in my pc when it's off, I see the little led on my mobo. But how can I hook-up something else that will work when my pc is off? For example, I have a gadget that works on 24v. How could I hook that up so that it's running, even though my pc is turned off? Dig? Oh, one more thing. If the PSU doesn't have 24v, how much can I get out of it when it's off? Where are those wires?
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    The only active line when a PSU is on while the system is off is the +5vsb line, which only supplies anywhere between 1-3A (depends on the power supply in question). If you wanted to power something that runs at 24v, then you'd need a step-up transformer. The thing about this is that you're basically trading volts for amps. If you had a 24v .5A device, then on the 5v supply side, you'd be drawing at least 2.5A (more because of losses). That'll be too much for most power supplies.
  3. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Just a note to avoid confusion to curme, a step up transformer cannot be used directly from the output of the power supply, in fact a step up transformer would be difficult to find that had the correct turns ratio. You'd need a DC-DC converter, or a simple charge pump.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    A simpler way would be to use the 5v VSB supply to keep a relay on whilever the PSU is plugged in, switching a separate mains:24v supply.
    It means tapping into the mains inside the PSU, so make sure your skills are up to it. :nono:
  5. whypick1
    17 Oct 2002
    You're right Stevey, I tend to get the two mixed up in my head.
    edit: cool, 1234 posts. Now I know my ABCs! </Ralph Wiggum>
  6. Pandalet
    Pandalet What's a Dremel?
    29 Dec 2003
    following on from our local superhero, you might find these monolithic regulators handy - they produce a regulated 24V (well, the 24V version does, anyway) from an input of anything between 27V and 40V. All you need to make them go from the mains is a transformer with a rectifier and a suppression capacitor or two. Add in a relay for the switching, and you're off.
    As has been said, though, you'll be working with mains-grade power, not to mention poking around in your PSU, so if you aren't sure of your skills, then don't :nono:
