I corupted a file so windows would not boot when I put the fsb to 140 and the voltage up to 1.8 and windows could not boot how can I stop this? XP2100 512mb DDR @ 333mhz Gainward GF4 4600 Soyo Dragon Ultra Platinum Edition 2x Maxtor 60gb 7200rpm in raid 0 if that helps
That may well indicate that you have gone just past your maximum possible overclock! Lower the settings slightly until you have a stable system with no errors.
Yes I have now done that not as fast as I wanted but its better then nothing!! XP are pants at overclocking shame P4's a re soooo expensive!!
Normally read/write errors are due to the FSB bus being too high - just try lowering it a notch or two.
I could probably push my 1.4 past 148 FSB, but It wont post, I may once try it with out the NIC and second and third vid cards, it might help me to 150 or more. on second thought it could be my cheap ram.
