how can you tell....
Discussion in 'Tech Support' started by devo, 23 Feb 2007.
  1. devo
    devo What's a Dremel?
    22 Feb 2007
    how can u tell if ur cpu is fried? Will the processor still become warm if u turn on the computer when your cpu is fried?
  2. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    If it's dead, it's dead. Like anything that is dead, it stays cold.
    What happened?
  3. devo
    22 Feb 2007
    im not really sure... i freakin kicked my comp on accident and the fan and heatsink on the cpu kinda nudged off while my computer was on. then my comp died and monitor went black.
    after that i tried turning on my pc, it seemed like everthing was fine but the monitor had no signal and stayed black. sooo im hoping that it is my cpu messed up cus i just orderd a intel core2duo
  4. sackingz123
    sackingz123 What's a Dremel?
    7 Feb 2007
    yup. cpu is dead. giving voltage to a cpu without a heatsink. its dead.
  5. DougEdey
    5 Jul 2005
    Make sure nothing else has slipped.
    If the HSF "nudged" off either you didn't fit it properly or you booted it.
  6. Masterchief
    Masterchief Banned
    23 Feb 2007
    try remounting the cpu and then the heatsink
  7. krimson
    krimson What's a Dremel?
    16 Nov 2006
    one easy way is to throw in an old cpu in there, if it boots with the old one, and not with the new one, then you know whats wrong!
