Modding How Could i hook up this 4x20 VFD?
Discussion in 'Modding' started by tm36usa, 9 Mar 2004.
  1. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    I am thinking of buying a 4x20 Noritake VFD
    How would i hook this up. It looks like it has a mobo serial hook up on the back. Plz HELP!!
    Now for a pic.
    Someone help!
  2. deadly-app
    deadly-app What's a Dremel?
    9 Mar 2004
    i have seen someone chop off a serial connector on the mobo and attach wires to the pins in the mobo where the serial plug was. that way you can keep it all internal. I have also seen it where they took the serial cord for the lcd and ran it outside of the case through a hole in a pci slot and then plugged it in. either way works.
  3. The_Sub
    The_Sub What's a Dremel?
    16 Nov 2003
    Read through the LCD FAQ and learn. There is a lot of useful info there including, but not limited to, how to wire it up and what software will work with the display.
  4. Morphine
    Morphine weeee!
    23 Feb 2002
    model numbers are also super useful
  5. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    Its a CU20045SCPB-T23A. Very easy to use. VFD thinger at VFD world has pinout diagram for parallel port, and datasheets. Ive written PIC code to use them.
  6. Morphine
    Morphine weeee!
    23 Feb 2002
    yeah, i thought it looked very similar to a noritake vfd i had. I forgot the model number of mine, but the two are very similar.
  7. tm36usa
    21 Jan 2004
    So i can buy it and then just plug the serial cable into it? I know what kind it would need to fit in the plug.
  8. Hazer
    14 Apr 2003
    No. It has 2 connectors. One is a 16 pin parallel connector that has an IDC header (same things you see on motherboards). The second connector is a 3 pin header that you can use for alternate power and serial communication. It looks a little like a fan header. And, No, you cannot simply wire this directly to your motherboard. The serial port swings from -12V to 12V for signalling, while the serial interface for the VFD is 0V to 5V. You would need to condition the serial port signals using a MAX232 transciever IC.
    The links I gave earlier show how to directly connect it to the paralell port. A $2USD 25DB connector from radioshack and a few wires. VFDthinger and also LCDStudio can control these displays. They are really easy commands.
  9. tm36usa
    21 Jan 2004
    Thanks so much!!!! I shall get to work with hooking it up. I will post pics when i get it done.
