Modding HoW dA Fook do i remove this led
Discussion in 'Modding' started by Seth, 25 Mar 2002.
  1. Seth
    Seth What's a Dremel?
    14 Mar 2002
    okay so I am about to mod my natural keyboard from microshaft. I need to know if there is a special way to remove the old leds because i don't want to cut them off and rune the piece of board.
    thanks people
  2. Seth
    14 Mar 2002
    fine then no one answer. well actually i got impatient and just ripped it out. hard to get solder off back though.
  3. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    if you have a solder gun you could have just tapped both leads on the back of the pcb and then quickly pulled the led out, Dammed if I know how to get another led back in though.
  4. Arcane
    Arcane Minimodder
    24 Mar 2002
    :eyebrow:
    the way i do those is take your iron and heat one lead at a time...kinda walk it out....works the same for installing new ones.
    heat one lead and pull...heat other lead then pull...takes longer but it's less messy if you're not too swift with a soldering iron.
    to go back in just heat solder and press...then heat other lead and press...etc...etc...
    or break out the hammer... you choose
    :D
  5. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    A Desoldering Pump works miracles and they cost less than $5
  6. Seth
    14 Mar 2002
    thanks guys. I was thinking something along the same lines last night
    :dude:
  7. MrBadidea
    MrBadidea What's a Dremel?
    10 Nov 2001
    eh? WTF??
    Since when did microshaft solder the LED's anywhere?
    I got a nautural keyboard that I have pu some Bl00 LED's in and there was no where to solder the LED's on - insted I had to bend the legs of the new LED's so that they would make contact with that piece of membrane or whatever the hoobajooba it is
