A/V How do I clean my LCD monitor?
Discussion in 'Hardware' started by lessthanjakejohn, 18 Jan 2004.
  1. lessthanjakejohn
    lessthanjakejohn What's a Dremel?
    18 Jan 2004
    My monitor is dirty. What is the best way to clean it?
  2. oshta
    oshta Guest
    yeah - also interested!!
  3. prophecy421
    prophecy421 What's a Dremel?
    30 Jan 2004
    Try gasoline and a match that works great for me... :naughty: on a serious note.. you can get LCD cleaning wipes from most big office supply stores (staples and office max for example) radioshack may have them, and maybe even worst buy.. err umm best buy :D they are somewhat inexpensive and do a decent job. Just dont scrub on the LCD as if you are hercules that could scratch the thin membrane or even crack the glass, never a good thing to happen
  4. -=Craig=-
    -=Craig=- What's a Dremel?
    3 Feb 2004
    i bought some from a local market they were pretty good and they are anti static i dont my laptops screen my tv my pc monitor and my keyboard with them and they come out really well and as for my mouse well it looks new again
  5. shroom
    shroom What's a Dremel?
    6 Aug 2003
    This is right from a tech manual, so get ready its a tough job.
    Ok. Now.
    Take a deep breath.
    Go get a towel, or a sock or something.
    And use luke warm water :D
    I'm not kidding, its whats recommended, and its amazingly effective. If you strongly desire to use a solvent, or you spooged on your monitor and water isnt enough, any non-ammonia based cleaner is good. The ammonia is what eats through the plastic. Same rule applies to most pairs of glasses, although most people ignore it.
  6. Mat-d-Rat
    Mat-d-Rat Drive it to the edge baby
    30 Aug 2001
    Windolene - or any glass cleaner like that, does a terrific job. Been using it on laptops for as long as I can remember. No it does no damage, and yes I've also use it on my pair og LG Flatron 1710b's
