Modding How do i cut this?
Discussion in 'Modding' started by Bboy_Jon, 26 Feb 2005.
  1. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    I might do this window
    how do i cut the dragon? what bits for a dremel do i need?
    im either gonna cut that or put a piece of acrylic there and etch, but how do i etch?
    or should i do this?
  2. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    If i recall correctly, there are special dremel kits that have all sorts of different tools you can use. The kit costs a fair bit more then some standard cutting wheels though.
  3. DarkInferno
    DarkInferno Minimodder
    28 Nov 2004
    the first dragon will be bloody hard to cut, mebby redesign it somehow.. or make a template and spray an etch-esque substance on the back of the acrylic (might be more even then the etching I've seen done with dremals).
    and your second design has been over done in my opinion, well its a bit standard and unoriginal.
  4. T-MINUS 10
    T-MINUS 10 Banned
    13 Feb 2005
    do the first one, it looks awesome :rock: but it would be a bit harder to cut :duh:
  5. m0ng0lh0rde
    m0ng0lh0rde What's a Dremel?
    5 Jun 2004
    If money is less of an issue, look around for someplace that might do laser cutting, or water jet cutting...
    Of course, I won't be responisble if the price causes heart failure, divorce, or bankruptcy...
  6. Halgy3000
    Halgy3000 What's a Dremel?
    22 Mar 2004
    I'm no expert, but I believe a lightsaber will do nicely.
    PEACE
  7. KidModder
    KidModder What's a Dremel?
    22 Dec 2004
  8. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ya im thinking about doing that for the sake of easiness, and i kinda wanna have 2 top windows on both sides so you can see through the case
  9. JoyRider
    JoyRider What's a Dremel?
    7 Jun 2004
    A lot of patience + a vast hand + dremel cutting wheels (incl. fibre reinforced) + cheap dremel tool =
    It'll be a lot easier then mine was.....just my 2 cents...
  10. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ok well i think im gonna go pick up probly some more renforced disks, a carbide cutter and an etching bit from walmart, would that be good?
  11. T-MINUS 10
    T-MINUS 10 Banned
    13 Feb 2005
    wow! tht window is awesome, :jawdrop: you the man :thumb:
  12. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    I think you mean a steady hand, not a vast one. A vast hand implies you have a really ginormous hand :lol:
    for you non-dutchies: een vaste hand = a steady hand. :D
  13. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    well i have a pretty steady hand
    ya so im gonna pick up another pack of reenforced discs, a carbide cutter, and then an etchers bit
    and all my paint and stuff
  14. JoyRider
    7 Jun 2004
    xD, soz. Sometimes I mix dutch and english words in sentences :worried: because I prefer to talk english but live in NL. 'neways, he's right. I meant a steady hand.
    Here's a big hint: SAVE UP THE USED (non-cracked/damaged....just smaller) CUTTING DISCS. 'Cos you'll need a lot of them to do the tiny spaces and curves.
    hint 2: To do the very small parts. Dremel at the inside of the side panel (because the disc is round, the outside will have a smaller gap than the inside. This way it'll look better at the outside since you won't see the metal of the side panel in the gap on the outside.)
    hint3: If you plan to dremel like me (6 hours straight), get something for your neck....I could barely move my head :dremel:
  15. zer0_c00l
    zer0_c00l What's a Dremel?
    4 Jan 2005
    nice looking mod good LUCK
    :dremel: :dremel: :dremel:
  16. DarkInferno
    28 Nov 2004
    after I've seen JoyRider's fantastic piece of work, I'll have to change my opinion to option 1. but i still think some of the finer work will be hard... but good luck :dremel:
  17. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    Ya ill be cutting all of it from the inside
    Im just gonna try the top half of the dragon first, then if its too hard just make dual windows and etch the dragon (or a more complicated thing)
    what do you think would look better dual windows with the dragon etched on the top window (a top window on both side panels) or the dragon cut out?
    so i just print the pic of the dragon right? and then draw it on the side panel after tapin it up?
  18. KidModder
    22 Dec 2004
    Or youy could tape the picture really tight to the side and cut throgh that if you have bad handwriting.
  19. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    handwriting? lol
    ya i meant tape the pic up, its just what do i print it with (ms word or something?) cuz its probly too big for one piece of paper
    but ya should i turn the dragon so the head faces the cd drives?
    If i do, do the dragon what should i do on my other side panel? (the one that you dont normally see)
    i think it would be kinda cool for a top window on both sides, and just etching the dragon on the top window (the one that you mostly see) cuz i think being able to see right through the case would be cool
    like this window layout
    just with the same top window on the other side panel, so you see right through it and a dragon etched on the top panel, should i do it?
  20. JoyRider
    7 Jun 2004
    If you do the dragon without top window then you shouldn't point the head to the cd-drives, I think it would look shite that way....The cool part should not be messed up by the bg or its enviroment.
    Top windows could be cool, but then I think you'd better not etch the dragon on the top window, but leave it clear. Instead etch the dragon in the bottom window (only lines, don't do whole parts, no one can level-etch at the same height at a whole part. If you do want to do the parts, try sandblasting or laser)
    Etching:
    You could print out the drawing and then cut out the lines what you want to etch/dremel. Or try laying down onto the place you want it and then get a cloth and thinner. Rub some over the letters and peel off the paper. Viola, letters on your side panel/plexi glass.
    And it's not too hard, I guarantee you that since the side panel you saw was my very first one......I've only made a 2nd (spiderweb concept) since then.
