Windows How do I make a bootable Win 7 RC 1 disk?
Discussion in 'Software' started by Wozzname, 10 May 2009.
  1. Wozzname
    Wozzname Some random guy
    16 Jan 2009
    As the topic says, how do I go about doing this? If you could go through the whole process that'd be fantastic.
    For starters, I've downloaded the Windows 7 RC1 64-bit from Microsoft. The file's description is "file", and can be opened with 7-Zip File Manager.
  2. Psy-UK
    Psy-UK What's a Dremel?
    22 Jan 2009
    Download CDBurnerXP. Get a blank DVD, run CDBurnerXP, choose 'Burn an ISO Image', choose the location that the ISO is located then click burn!
  3. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    or if you set CBXP to associate with ISO files, you just double click on the file and press "OK". :)
  4. intel17
    intel17 CPC Refugee ^_^
    6 May 2009
    or you could give imgBurn a go. Install then and then double click on the ISO file of W7 and follow on screen instructions.
    HTH
    -Pete
  5. Wozzname
    16 Jan 2009
    The file isn't recognised as an ISO file though. Its type of file is "File"
  6. hitman012
    hitman012 Minimodder
    6 May 2005
    Then put a .iso extension on the end.
  7. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    +1 for Imgburn. It is very easy to use.
  8. Wozzname
    16 Jan 2009
    This was my problem right here, the disks good to go now.
    Thanks everyone for the help!
  9. GoodBytes
    20 Jan 2007
    imgburn and ISOBuster and Active ISO Burner are softwares recommanded My Microsoft.
    All your questions you may have are answered here (installation instructions of Windows 7 RC on Windows 7 page):
    http://www.microsoft.com/windows/windows-7/installation-instructions.aspx
    It's good to open your eyes ;) I know I know, excitement prevents you from reading and looking for thing... I get that. :D
  10. barack
    barack What's a Dremel?
    11 May 2009
    yes i agree with psy-uk,and as far as software is concern ISObuster should be used.
  11. NikoBellic
    NikoBellic Tech Addict
    9 May 2009
    Just thought I'd add!,
    I have Installed W7 from a 4GB USB PD, and it is Much faster than installing from a disc!!.
    I would definately reccomend to anyone with a Big enough USB PD to try installing it from USB!!.
