Networks How Do I share NTL Cable ?
Discussion in 'Hardware' started by boycee, 25 Jan 2002.
  1. boycee
    boycee What's a Dremel?
    9 Jan 2002
    I have two machines,
    1) Win 98 SE
    2) Win 2000 Professional
    They are connected via a crossover cable, but can ping each other but not browse each others files, despite file sharing being on.
    The file sharing aint to important, mainly im interested in the sharing of the internet.
  2. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    Which one has the connection to the net?
  3. boycee
    9 Jan 2002
    they now both have win98, all connected by patch cable.
    PC 1 one can ping PC2 but cant see it in network neighborhood.
  4. BannedMojo
    BannedMojo Banned
    14 Jan 2002
    are the network protocols etc exactly the same (Ive had stupid problems like this in the past), and also what are the NICs on them (Network cards), i had a 10/100 NIC which was set with autosense (So it would put it on 10 or 100 depending on the other one) and it wouldnt work at all - If you use 2 identical cards your sure to have no probs at all
  5. The1
    The1 What's a Dremel?
    14 Jan 2002
    make sure you have optain IP automaticaly on both of them. Also try windows Me if you have it.
  6. herbs
    herbs Nobody but us chickens
    7 May 2001
    Why would he want both to obtain an ip automatically?
    If im correct in thinking win 2k pro can not act as a dhcp server even if it could then the dhcp server would need a static ip to act as a server on his network.
    And telling him to use Win ME are you mad?
    If you can ping each other then it seems your tcp/ip is working, just check your machines are in the same workgroup and if you are using a software firewall that you set the settings to allow the machines to access each other. Also the obvious is to do a find computer and enter the pc name you want to connect to, as file and print sharing browser on windows is slow.
    Are you using netbeui for file/print sharing?
    To share the internet you don't use file/print sharing try ICS or winroute etc. ICS comes with 2k and win98se just check the help files.
  7. The1
    14 Jan 2002
    I was only suggesting that cause win ME has built in internet sharing and to use microsoft's crappy one you have to use an auto obtain ip. That way they dont need to get any extra software unless they dont have ME, also i didnt read they had 2000 :D
  8. Phil
    Phil What's a Dremel?
    19 Jul 2001
    not true....
  9. Sim0n
    Sim0n rm -rf /
    14 Dec 2001
    Wait a minute, im assuming say PC1 and PC2,
    im assuming the PC1 has two network cards, one as the input for the modem, and the other a output for PC2, and PC2 kust has a input.
    you need a cross-over cable, not a patch to talk between the two PCs.
    once you get a cross-over cable you should be alright.
    Make sure your give them similar names, like PCMASTER and PCSLAVE.
    and give them the same domain eg HOME.
    Then give them IP addresses,
    89.1.1.1 = PCMASTER
    89.1.1.2 = PCSLAVE
    Then on the master, obtain IP automatically (so it can find the NTL server info), then on the slave give it the specific IP 89.1.1.1 to connect to the internet.
    This should help, as when the slave hits the master, the master will just hit the cable modem and head outwards from there.
  10. PhsyCon
    PhsyCon What's a Dremel?
    7 Dec 2001
    Cypher they are ;)
    Do you have ICS running? or a proxy of some kind?
  11. Medic6666
    Medic6666 What's a Dremel?
    28 Nov 2001
    Get a cheap router/switch. You can then assign this to access the internet and then both machines can access the internet through this.
    Good Luck
    Medic6666
  12. dhcp
    dhcp What's a Dremel?
    30 Apr 2001
    This seems very easy. For your server assign it an Ip address of 192.16.1.1 with a subnet mask of 255.255.255.0 and a default gateway of 192.168.1.1
    Get a small program called Winroute and install that. Its freely available on the internet but after 30 days I think it loses some of the features without it being registered.
    Once installed, it really is a doddle to configure. Just make sure that you select the option to allow DHCP to work.
    On your client set the TCP/IP to automatically pickup an IP address.
    You should notice that your client will also now be able to see your server without any problems and be able to use ICS which will be enabled through Winroute.
    You must realise that Winroute is pretty good but only supports IP forwarding.
    If you want to go one better you need to get Sygate. This is a more complex utilty than Winroute as you can setup blacklists/white lists. All is explained in the program itself so dont fret.
    give it a try and let me know of the outcome.
    Peace
    Edited by Koolvin.
  13. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    Bill,
    I edited, we do not promote Iilegal software cracking... if you like it buy it after trial version.
  14. Sim0n
    Sim0n rm -rf /
    14 Dec 2001
    God, he is away for days then he jumps in from nowhere to protect copyight infridgment.
    Nice to see ya back KV
  15. Koolvin
    12 Mar 2001
    I am always here watching and stalking! :eek:
  16. dhcp
    30 Apr 2001
    Ugh,
    I didnt realise about your piracy thing, well I did kinda, hence why no site names were given!
    http://bounce.to/dhcp
    Thats my site, no warez, non illegal!
  17. Koolvin
    12 Mar 2001
    PIMP
