how do i take a motherboard out of an hp pavilion 503n?
Discussion in 'Tech Support' started by coltsrock, 5 Apr 2006.
  1. coltsrock
    coltsrock What's a Dremel?
    5 Apr 2006
    does anyone know how to take a motherboard out of a hp pavilion 503n
    the screws are out and i still cant get it out
  2. Krikkit
    21 Jan 2003
    There might be some plastic mounts that go through motherboard holes which hold it to the tray as supports.
    They poke through some of the holes with an arrow-head type shape. Get some pliers and cut them off, then the mobo should lift right out. :)
  3. coltsrock
    5 Apr 2006
    thanks alot man
  4. coltsrock
    5 Apr 2006
    it worked thank you so much!!!!!!!!!!
  5. Krikkit
    21 Jan 2003
    Good stuff, glad to help. I've had a couple of mobo removals hampered by those blasted things... :\
