How do i update my motherboard driver/software?
Discussion in 'Tech Support' started by Solidus, 8 Nov 2007.
  1. Solidus
    Solidus Superhuman
    26 Dec 2005
    Iv never done this before, im running a Asus P5B Deluxe (link:http://www.bit-tech.net/hardware/2006/08/03/asus_p5b_deluxe_wifi_ap_edn/2) and im trying to update the drivers for it since im having troble with gears of wars. Iv NEVER done anything like this before and im a complete noob, does anyone know where i can find the latest drivers for the board or how to go about updating them? Im going to try google now but iv tried to search in the past with no luck, i doubt il get any where this time either. Im not sure how to go about this so any advice or guide for a noob like me would be more than welcome!
    Thanks in advance guys
    -Solidus
  2. capnPedro
    11 Apr 2007
    Asus' website should provide .exe files which run just like regular installers to update the drivers.
    Unless you mean updating the BIOS...
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    http://support.asus.com/download/download.aspx
    Just stick the model in the box.
    That's also there but avoid the beta versions until you're less n00b. ;)
    BIOS-flashing instructions at Asus too.
    Which BIOS version is installed?
  4. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    Just to chip in my 2 cents, even though you have the ability with the board. DO NOT UPDATE THE BIOS THROUGH WINDOWS!.
    Sorry for yelling, but even on the asus website it says in large red letters not to do it.
  5. capnPedro
    11 Apr 2007
    Yeah, agreed. The one time I tried that, I bricked the board.
    Flashed BIOSes like 10 times through a boot disk without any problems though.
  6. Guest-16
    Guest-16 Guest
    I do it every single day, never had a problem.
