Modding How do I wire up leds in my case?
Discussion in 'Modding' started by retrogamer, 22 Sep 2004.
  1. retrogamer
    retrogamer What's a Dremel?
    23 Aug 2004
    [old]where can someone reccommend getting some LEDs (laser?) to light up the whole of a case and how many would it take to get nice and bright??? im planning on having a string of one colour, then another like green on one, red on another, UV on one you get me? ;) and then i can control them via switches on the front.
    but i dont know how many id need to light up the full thing and where to get them from???
    also i want some USb cable things that go into USB headers on the mobo to give me some front USB ports cheap :thumb:
    thanks :)[/old]
    ok if I buy these leds how do i hook em up??? :p
  2. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    try http://www.xoxide.com/ they got lazer LED's and stuff you shoudlbe able tyo find what you are looking for
  3. TZBull
    TZBull What's a Dremel?
    21 Sep 2004
  4. retrogamer
    23 Aug 2004
    thanks for the links :thumb:
    but erm (n00b question ahead) do I wire led's in series or parellel? im not sure as to what resistors id need or anything :S if they were in parralel id just need the same type for every led woulnt i? or is series better???
  5. retrogamer
    23 Aug 2004
  6. tk421
    tk421 Idiot.
    15 Jan 2002
  7. retrogamer
    23 Aug 2004
    thanks tk, i think i get the basic stuff... but can anyone tell me say if I had 5 leds on the 12v part would i be able to run these at 2v like the sugested part on my link to an led calulator somewhere above? or wouldnt this light up? also if i had 25 leds say altogether or perhaps 30 will these steal loads of power away from my hardware :worried: im gonna be runnin them off a 250w SilentX shuttle pPSu so i dont want that to effect anything...
    thanks
  8. Go4t
    Go4t i
    13 Dec 2003
    the shuttle silentX is a very powerfull 250w psu it wouldnt have any problems running many more leds
  9. retrogamer
    23 Aug 2004
    oh great :thumb: thanks for that boost of confidence there go4t :D well if that is the case I can have my big bunch o' leds then :p
    im planning on being able to contol the colour theme in my case for when i get bored :thumb: hope it goes well :)
    thanks for the help guys :dremel: mod on :rock:
  10. retrogamer
    23 Aug 2004
    oh still no one answer my question about the voltage being supplied to the leds... will a resistor sort everything out and will an led run bright and nice with 2v dropped onto it even if its a 3.3v??? or should i do the 3.3??? :sigh:
  11. Go4t
    Go4t i
    13 Dec 2003
    :search: for led resistor calculator
  12. retrogamer
    23 Aug 2004
    yep ive got that... i think ive got it sorrted now :p thanks for all the help anyways
  13. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
    LED's next to nothing power wise, bright, compact, durabe but it all comes at a cost, they are fairly expensive, but worth ever penny
