Development How do I write a SQL query involving a time stamp?
Discussion in 'Software' started by Captain Xarzu, 26 Apr 2016.
  1. Captain Xarzu
    Captain Xarzu What's a Dremel?
    22 Aug 2007
    QUOTE_ID is a character string
    CREATE_DTG is a date time type
    RETENTION_LEAD_TRACK is a table
    This sql statement cmf.CommandText = "SELECT QUOTE_ID FROM RETENTION_LEAD_TRACK where CREATE_DTG > '2016 - 04 - 25 18:18:15.2891'"
    throws this error {"Conversion failed when converting date and/or time from character string."}
  2. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    What sql database are you writing this for?
  3. faugusztin
    11 Aug 2008
  4. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    spaces between the YYYY-MM-DD may be your issue?
  5. phinix
    phinix RIP Waynio...
    28 Apr 2006
    I would use CONVERT to change it in a query
  6. cjmUK
    cjmUK Old git.
    9 Feb 2004
    I think it all depends on where your actual date is coming from...
    But if push comes to shove, use CAST over CONVERT because it is ANSI compliant and preserves precision:
    Code:
    ...WHERE CREATE_DTG > CAST('2016 - 04 - 25 18:18:15.2891' AS DateTime)
