Displays How do you clean your screen?
Discussion in 'Hardware' started by GeorgeK, 31 Aug 2019.
  1. Chicken76
    Chicken76 Active Member
    10 Nov 2009
    Some people say "only use water", and they're usually called "the police".
    I think a bit of alcohol helps. So I have a few shots of whisky and then heavily breathe over the more stubborn spots on the screen. Then wipe with a dry cloth (usually my sleeve). Repeat as needed.
  2. GeorgeK
    18 Sep 2010
    Repeat what? The whisky or the wiping? I do quite like the sound of this method
  3. yuusou
    yuusou Well-Known Member
    5 Nov 2006
    Well both obviously, the whiskey effect will only last you so long.
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    For scrubbing down stacks of Ultrasharps that have been splattered by years of coffee, noddles, soups, and godknowswhat: Can of Maxiclean spray foam, and a microfibre cloth. The Maxiclean is water-based, so the cloth is mandatory to avoid residual water dripping down into the screen when you turn it upright. Isopropyl doesn't do diddly-squat against heavy staining. These are all screens with plastic matt surfaces rather than glass + anti-glare coatings, so YMMV if you have a monitor with a more delicate surface.
    Chicken76 likes this.
  5. Chicken76
    10 Nov 2009
    Well hîc..., the perceived image quality is only a function of the screen's cleanliness and the alcohol-induced blurry vision. So mix and match the number of whiskey shots with the amount of smearing using your sleeve until you reach the image distortion level that works for you.
  6. edzieba
    14 Jan 2009
    A new AA technique: AAA - Alcohol Anti-Aliasing.
    Chicken76 and MLyons like this.
  7. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    Brillo pad and elbow grease.
    YMMV. :lol:
  8. Mister_Tad
    27 Dec 2002
    Muriatic acid jet-wash for those stubborn marks.
    edzieba and David like this.
  9. edzieba
    14 Jan 2009
    80-grit floor buffer. Sure the surface finish isn't the best, but think of the throughput!
    Vault-Tec and David like this.
  10. Anfield
    Anfield Well-Known Member
    15 Jan 2010
    At least that would get rid of the excessive glossiness of some screens:hehe:
