Modding how do you do those round fan inlets?
Discussion in 'Modding' started by FL@MeS, 16 Feb 2002.
  1. FL@MeS
    FL@MeS What's a Dremel?
    4 Jan 2002
    just to show you what i mean:
    this case rocks, btw spike...
    ya see those deep circular hole at the bottom of the case???
    how???
    i would really like to do that, but i have no clue -- anyone have any tutoials? :rofl: :rofl: :rofl:
  2. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    There just Sub Woofer tubes from a Hi-Fi shop i think..
  3. tk421
    tk421 Idiot.
    15 Jan 2002
    speaker port tubes. here.
  4. FL@MeS
    4 Jan 2002
    oh yeah, cheers -- it all makes sense looking @ my sub... i suppose you just glue
  5. tk421
    tk421 Idiot.
    15 Jan 2002
    actually , theres little ridges on the outside of the tube, tapering down, on mine i just cut the hole so it barely fit in , and shoved it till it locked in place, held by friction .
  6. Slink
    Slink B7
    7 Oct 2001
  7. benje
    benje What's a Dremel?
    4 Feb 2002
    You can also use the top half of a plastic funnel.
    _ _
    <=== < the top half of the funnel |
    \_ this bit > \_
    You know one of these, sorry for the lame ass drawin but I couldnt be botherd to upload a pic, sorry.
    Just cut the larger end of it off and use than as a round fan duct.
    All copywrite, bleh bleh etc to whoever I saw do this first :D
  8. benje
    4 Feb 2002
  9. benje
    4 Feb 2002
    sorry that went abit pear shaped, lol ignore the first post :rofl:
  10. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Those came from maplin.... they are sub ports
  11. FL@MeS
    4 Jan 2002
    thanks a lot for the posts,
    have i already said this?
    i think its original ideas (cool ideas) that make modding... well modding :D
  12. FL@MeS
    4 Jan 2002
    could i have a code for the sub ports, plz???? ;)
  13. seanblee
    seanblee What's a Dremel?
    17 Jun 2001
    Hey Fl@mes, you're in Newquay? You're a few miles down the road from me (I'm in St. Austell)!
    Anyway, sub port (officially 'Bass reflex tubes') codes. They're available in 35.5, 52.5, 40.5 and 54.7mm diameter sizes, and the codes are KS85G, KS84F, KS86T and KS87U respectively.
    Sean
  14. FL@MeS
    4 Jan 2002
  15. FL@MeS
    4 Jan 2002
    wow, im a multi-modder :D
