How do you get Artic Silver off a Proscessor?
Discussion in 'Hardware' started by DoubleSidedTape, 19 Jun 2004.
  1. DoubleSidedTape
    DoubleSidedTape What's a Dremel?
    26 Jan 2004
    I dont want to use water, how do i get that stuff off the proc?
  2. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    Rub it of with some cotton soacked in alcohol, that's what I use...
    Cheers,
    Mike
  3. Guest-16
    Guest-16 Guest
    isopropyl alcohol (nail varnish remover), alcohol-ethanol, meths, paintbrush cleaners (although these leave a nasty smell when you put the chip back in cause they arent pure solvent the "extra" cleaning stuff in it gets burnt off - but that's also brand dependent obviously). Generally any organic solvent should do it.
  4. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    I used alchohal and some toilet paper to get it off the heatsink/fan. Used a fingernail after putting some alchohol on the stuff to get it off the CPU. Works like a charm. :)
  5. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    I like 90% iopropyl (rubbing) alcohol, since it evaporates very quickly.
  6. neon85
    neon85 What's a Dremel?
    8 Jan 2002
    Get most of it off with tissue and then get a blob of bluetac comes off really easy.
    Leigh
