Development How do you load a bitmapimage in wpf?
Discussion in 'Software' started by Captain Xarzu, 2 Aug 2012.
  1. Captain Xarzu
    Captain Xarzu What's a Dremel?
    22 Aug 2007
    In a silverlight app, I have a BitmapImage defined as System.Windows.Media.Imaging.BitmapImage and it as a method called "SetSource" where I can set the source like this:
    Code:
    	BitmapImage bitmap = new BitmapImage();
    	System.IO.Stream stream = _scene.GetStream();
    	if (stream == null) return;
    	bitmap.SetSource(stream);
    In a WPF application I have also have a Bitmap image defined as System.Windows.Media.Imaging.BitmapImage but there is no SetSource method. How do I set the source in a WPF app like I do in a Silverlight app?
    Also, it is a stream, not a string. It is not a URI. so "UriSource" method does not work. I tried this:
    Code:
            bitmap.UriSource = new Uri(stream.ToString());
    And at runtime, it threw an error tha URI cannot be determined. Is the URI an identifier for the intranet? Are you sure that this is not a silverlight thing? I am doing a WPF application
  2. Plugs
    Plugs Minimodder
    5 Nov 2009
    Is there not a StreamSource property?
