Displays How do you use your screens?
Discussion in 'Hardware' started by Guest-23315, 3 Jul 2012.
  1. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    DisplayFusion will help you out there.
  2. Elton
    23 Jan 2009
    Ultramon/Display fusion. :D
    It's worth the money. (And if not.... :thumb:)
  3. Pookeyhead
    30 Jan 2004
    As others have said.. use Display Fusion. Look at my screen grabs... you'll see the task bar spreads across both screens, with a clock, start button and systray on each screen.
  4. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I have a Samsung SM2232BW on the left and a Samsung SM2233 on the right. Using DisplayFusion for the taskbars of course. I usually have my main programs (browser, IDE, game) on the left one while the right one is for background stuff like instant messaging, IRC and downloads. Generally the software setup is quite flexible and if I'm working on something that could use both screens, I do use them.
    Sometimes I feel like I'd need a third screen, probably for the same reason why I sometimes run out of RAM...
  5. law99
    law99 Custom User Title
    24 Sep 2009
    Ace. I'll be looking into those then. Last time I saw one it was halfbaked as your taskbar was essentially duplicated on either screen. Which sort of defeated the point for me.
  6. Pookeyhead
    30 Jan 2004
    You can set it to to be duplicated or only relevant windows are shown on each task bar.... so if I have a browser running on my main screen and minimise it, it will only be on my main screen task bar, not secondary etc.
    Each task bar has it's own clock and systray, which is actually a good thing. Display Fusion has loads of options.
  7. maestro0428
    maestro0428 Master Modder
    24 Jun 2010
    I have three screens at the moment. My ACER LED LCD 27" is my main monitor which is whatever I am doing at the time. I also have a 17" Planar LCD that my iTunes runs on. Then I have a Samsung 22" LCD that runs various other apps that I run. Its great for running multiple editing apps. I also have a 24" Asus LCD sitting on my floor and I am wondering, do I hook it up too for shits and giggles....probably not, off to eBay it goes. By the way, I have been using dual monitors since before LCDs came out and will never go back to a single monitor again.
  8. Pookeyhead
    30 Jan 2004
    My main 30" is used for everything, and the 20" is only used when image or video editing as I like a clean working area on the main image or timeline, and all tools on a separate screen (see my images on page 1). It's sometimes on when I needs more than one word doc open for something, and has also been useful to have a web page running while playing MORPGs.
    Usually though, it's just the big Eizo as a 30" had enough space to work with.
  9. law99
    24 Sep 2009
    Yes... I've been wondering this myself. I take it the resolution is big enough that it doesn't seem so cramped to just make your windows a custom size rather than just full screen over a couple. I'm down to one monitor now, so maybe I could sell this one and buy a larger screen instead?
  10. Pookeyhead
    30 Jan 2004
    For general use, a 30" (2560x1600) is plenty large enough for most things, yes. When it comes to Photoshop though, there's nothing better than having just a 30" with nothing but the image on it, and all your tools on a separate screen.
    If I had to have one screen, it would have to be at least 2560x1440.
