How does thise CPU, MOBO and ram do in OC?
Discussion in 'Hardware' started by X-W4rrioR, 4 Jul 2004.
  1. X-W4rrioR
    X-W4rrioR What's a Dremel?
    14 Oct 2003
    im buying a new computer, and im planing to OC my athlon 64 alitle
    i know thise processors arent that good in OC, but i still want that extra 3-400MHZ
    so im going to get thise :
    AMD643200+clawhammer (whats better, clawhammer or the newcaslte? im going with this one bcz it got the extra cache - good for gaming, or so ive been told)
    Epox EP-8kda3+
    and OCZ PC4000 CL 2.5 (2.5-4-4-8) 500MHZ 1 gig (512X2)
    im hoping to pull out a CG 3200, but thats plain luck..
    so, anything i should change in this setup?
  2. Mister_Tad
    27 Dec 2002
    change the ram
    the only place that PC4000 or faster can be used to its full potential is in a P4C system
    go for some low latency PC3200 or PC3500 that is known to overclock well, BH5, BH6, corsair XL or OCZ 2-2-2 would be good
  3. olv
    olv he's so bright
    23 Sep 2002
    I'd go for some OCZ EB (extended bandwidth) memory, does really high fsbs 250+ at 2.5,2,2,X on fairly low volts, its really good stuff. the 3700 does a little better then the 3500.
    What chipset does that epox board use? I'd go for the new Via pro one or nf3 250.
    You do realise your upgrade path is pretty none existant on sockket 754?
  4. X-W4rrioR
    14 Oct 2003
    Yes i do realise it mate ;]
    it uses the Nforce one
    well.. i looked around in newegg (the site ill be buying from)
    but i havent foud any 222 mems.. only 232X
    will those do aswell? (i never really got the timing thing)
  5. TMM
    TMM Modder
    12 Jan 2004
    the OCZ 3500/3700 EB arn't rated for 2.5,2,2,x, the 3500 is 2.5,3,2,x afaik.. But will most likely do 2.5,2,2,x if you raise the voltage
    :thumb:
  6. X-W4rrioR
    14 Oct 2003
    gotcha :p
    thanks mates!
