Windows How does win2k performs with 128 mb ram ?
Discussion in 'Software' started by ChillingSP, 12 Nov 2003.
  1. ChillingSP
    ChillingSP What's a Dremel?
    11 Jun 2003
    I'm going to assemble a new pc for general-purpose.
    1.7 ghz
    40 gb
    radeon 7200
    What can i expect by using win2k with 128 mb ram?
  2. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    pretty fast....
    I have a 433 Mhz celery with 64 Mb that runs fairly nice
  3. ChillingSP
    11 Jun 2003
    that's good :) :)
  4. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    I have Win2k running on a PII 233 with 128mb of ram. I won't say it's fast...but it runs with no problems. But it's about to become a Slackware box. :D
  5. Krikkit
    21 Jan 2003
    It should run ok on 128MB of RAM, dependson the speed of it and the processor obviously, but it should be ok providing you're not going to be having a huge RAM-sapping image/video editing spree...
  6. mushky
    mushky gimme snails
    24 Mar 2003
    i run win2k on celly 500s with 128 ram at work. They do a good enough job. They seem to cope with lots of officey things open at once, even a bit of photoshop here + there. Its definately preferable to winxp in that situation i think.
  7. ChillingSP
    11 Jun 2003
    Doesn't xp suck more resources than win2k ?
  8. Carbon
    Carbon Banned
    8 Jan 2003
    yes it does chilling, xp does with all its girly nice graphics
  9. ChillingSP
    11 Jun 2003
    Ehm... i missed the "to" :blush: .
    It's time for me to go to sleep i think. :rolleyes:
  10. mushky
    mushky gimme snails
    24 Mar 2003
    Sorry, bad sentence :)
    you can turn off all the girly bits on winXP but even then it still seems to be more resource hungry then 2K. Theres a few useful things in XP i like over 2K but you can get them seperately i think. Mainly its the "filmstrip" folder view in explorer which is not sorely missed.
  11. tk421
    tk421 Idiot.
    15 Jan 2002
    personally, i wouldnt put xp on a box with less than a 1ghz/256mb setup, especially if its a low-cache chip like a cele or a duron.
    2k is comfortable on anything from a p2 400 up, as long as you have enuff ram. 128 would be ok as long as you dont wat to multi-task like crazy, or run lots of stuff in the tray.
    i prefer 256 or 384 on a machine that slow though.
    i run 2k on a k6/2 with 96mb ram, and its ok for surfing the net, or mirc, but i dont try to push it. the onboard graphics in that system tend to freeze the box if i try to play a dvd or divx/vcd/mpeg on it ...
    so, it totally depends on what you want to do with it, and what level of performance you want out of it.
    personally, i'd just scrimp up the $$ for another 128 stick. your system will just run better overall.
