Other How durable is Ikea furniture?
Discussion in 'General' started by RotoSequence, 2 Jun 2009.
  1. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    I'm looking at getting a new sofa, and Ikea's 3 seat Ektorp Sofa currently has my eye. What I want to know is, would it take a combined weight of, for extreme's sake, 700 pounds and not give out?
    I have some heavy relatives, and I don't want the couch to break under use. :blush:
  2. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    lol
    :D
    Best bet, if you have access to the sofa, is to look for solid construction. Tell the sales people you want to flip the thing over to inspect the underside. I mean really abuse the thing on the sales floor, then ask for one from the back. That is the sole purpose of 'floor demos', to be demo-lished. ;) :D
    boiled_elephant likes this.
  3. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    I always found the biggest issue with Ikea anything is that it's not built to be moved around much.
    Computer desk's for example, cant survive a lot of apartment moves.
    As for weight, I agree with outlawaol. Take a look at it on the floor. I've seen some Ikea stuff that is pretty solid. And other stuff that is just not up to par.
  4. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    Try the flame test. If it is particle board it will only take about 5min to ignite and burn up. If it is hardwood it will take about 30min.
    And I wonder why i keep getting kicked out of furniture stores. :sigh:
  5. jhanlon303
    7 Sep 2006
    Oh! Me and the deaf, dumb, blind nymphomaniac triplets! Serious couch testing. :D Were I young again.
    john
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    Not very, a girl (130 lbs?) jumped on my Ikea-bought bed, and the frame snapped in half.
  7. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    Yeah ive had an ikea table destoryed by a 7 stone girl... Sofas might be a little better built tho
    RwD
  8. docodine
    10 Feb 2007
    I love the things they sell, but rarely does their stuff feel solid in-store.
    During assembly, slipping in some grommets and less skimpy nuts/bolts will greatly reduce squeakiness in the long run. If the thing you're buying seems too gimmicky, it probably doesn't actually work in a real household.
  9. Veles
    Veles DUR HUR
    18 Nov 2005
    I've found they range from tough as nails to as flimsy as a piece of paper. Just best to test the ones in store really and try to figure out if they'd be ok.
  10. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    remove all the wood and rebuild with scaffolding.
  11. Unicorn
    25 Jul 2006
    Your living room must be EPIC :D
    Some of it is grand. I have quite a lot of shelves and cabinets etc in my uni house from Ikea and the landlord actually got a large "L" shaped sofa for our living room last year. It's really well built and has had 8 or 9 of us on it at a time watching movies etc and hasn't shown any signs of being weak or breaking. Some of them are great but some that we saw on the shop floor were flimsy so like the others have said you just have to take a good look at it before you buy it. Make sure there are plenty of cross-members on the underside, and that it's made from pretty thick wood - those are good signs of a strong sofa.
  12. Krikkit
    21 Jan 2003
    I think the sofa range is plenty hefty enough really.
    I had a sofabed at home for a while, and although it was a rubbish bed, it was very robust indeed.
    As said, just pitch up and start molesting the example on the demo area. :)
  13. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    this. most of their really cheap stuff falls apart very quickly. but the more expensive ranges are very good. their GALANT range of work furniture is very robust and can take being moved around and dismantled a lot, mainly because all the screw points are into plastic lugs drilled into the wood surface rather than just straight into the wood.
    your best bet is to go into the store and be quite heavy handed with the stuff as you check it out, watching for any creaks or flimsiness. that, and just stay well away from the cheapest stuff they sell.
    (another thing: ikea beds? awful. stay together well enough but SO CREAKY. ugh. really, really can't wait to get a new one)
  14. Krikkit
    21 Jan 2003
    That's the golden rule with anything though really, if you pay peanuts, you get rubbish.
  15. eek
    eek CAMRA ***.
    23 Jan 2002
    As above, it could go either way (flimsy rubbish or solid as a rock).
    I've typically found (unsurprisingly) that it is the more expensive stuff that is more solid, by which time the price is on par with other places that don't come with the Ikea look/feel/stigma.
    Our Ikea wardobe is only 18 months old and isn't healthy. In hindsight I wish we'd spent more on something more decent up front rather than saving a few pennies and having to replace it more frequently.
  16. kingred
    kingred Surfacing sucks!
    27 Mar 2008
  17. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    Sofas are usually ok, had a few springs go in some that I got from there..
    Beds on the other hand. Don't bother. My girlfriend bought one recently and the slats keep falling through due to the side bowing out because of the pisspoor quality of the struts that are meant to keep it rigid and in shape. It's currently being held together with lashing and ratchet tie downs meant for trucks.
  18. Fod
    26 Aug 2004
    YES. don't buy the flexible slats. ugh. it's not nice when you are asleep in bed all relaxed and POP *fall*
  19. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    My bed has slats which aren't held in place so they all seem to migrate together in some kind of weird bed-slat entrophy.
    Also trying some of the softer mattresses is Ikea felt like felt on top of a rock. I'm barely 60Kg/120lbs (freakishly light) and I still went for the hardest mattress.
  20. capnPedro
    11 Apr 2007
    Ikea beds are funny sizes aren't they? They only take dodgy continental-European sizes mattresses? Or is that just FUD?
