How Have You modded Your PSU?
Discussion in 'Modding' started by ConKbot of Doom, 3 Jul 2003.
What PSU mods do you have?
  1. Replaced the fan
    47 vote(s)
    59.5%
  2. New cover
    17 vote(s)
    21.5%
  3. Lighting
    24 vote(s)
    30.4%
  4. Other (do tell)
    45 vote(s)
    57.0%
  5. Another Other
    17 vote(s)
    21.5%
Multiple votes are allowed.
  1. dhutch
    dhutch Banned
    10 Apr 2003
    replaced fan with papst 80mm
    moved thermister (temp sensor) to in front of the fan and removed grill altogether!!
  2. ernie
    ernie What's a Dremel?
    27 Jan 2003
    cleaned up the wiring for all 3 of my PSU's other than that they are all stock. antec's btw
  3. OrbDemon
    OrbDemon What's a Dremel?
    6 Jul 2003
    One thing I've wondered about, is wether or not removing the PSU from its box effects the sheilding in anyway. Afterall rogue magnetic and electric fields are not what you want anywhere near your memory/hdds.
    Anyone have any info on this? I was considering putting it in a perspex box instead of the ugly steel.
  4. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    the box tends to be connected to ground (to ground through the whole case).
    this will have to connect somewhere.
  5. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    I know in my PSU there is a wire going strait from the power connector to a ground bolt on the casing. The black wires are connected to ground by tinned traces around the screw holes on the PCB, so that means the whole thing is grounded and stopping EMI.
    Given that there are typically 2 transformers, and more inductors, I would guess that you would get more EMI in your case.
  6. ChillingSP
    ChillingSP What's a Dremel?
    11 Jun 2003
    I just painted the cage in red and cables in black, not much work but a joy for the eyes :p
  7. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    I have just modded my PSU to be silent.
    I've got a Q-tech 550 and have changed the 33db standard fans with YS-tech 20db silent ones. Also got rid of the P4 cable as im never ever gonna get a P4 if i was i don't think id have a Q-tech psu .
    Thats about it :D
    OOOoooooo i also spiral wrapped the atx lead :p
  8. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    I modded my QTECH 550W PSU as follows :
    * Removed all stickers
    * Installed a switch
    * Replaced fans with Antec blue LED ones
    * Made another small hole in the PSU to take the fan wires out as they will plug into my DigiDoc 5 unit
    * Cut off unused / unwanted cabling
    * Braided all remaining cables
    * Vinyl painted all the connectors black
    * Fitted rubber grommets for the 2 fans
    More details including pictures can be seen by viewing my Project Annihilator in my sig ;)
  9. Dad
    Dad You talkin to me?
    15 Apr 2003
    Chopped off the 4-pin P4 power and ran them into small 2-pin headers for case fans, sleeved all cables and painted.
  10. Supercool
    Supercool Gone.
    31 May 2003
    How come whenever I visit this forum, this thread is always marked as having new replies? :confused:
    /me kicks vBull
  11. KrazyIvan
    KrazyIvan What's a Dremel?
    18 Oct 2002
    I have removed stickers, painted, and installed some Red LED's in mine.
  12. Pug
    Pug What's a Heatsink?
    16 May 2002
    Turned the case it lived in upside-down and fitted a 120mm Papst, a custom grille and an alu mesh dustscreen.
    (Want to add a socket on it for my pump next)
    Stripped one of the first production w/c PSUs ever to enter the country and voided the warranty by modding the pump relay lead and changing the pipe fittings... :dremel: :D
  13. 486hawk
    486hawk What's a Dremel?
    18 Jul 2003
    Lets see.....
    Changed out micro AT connector with a normal sized one
    And if I get time change the ac out socket with a plug, for my modem's power brick.
  14. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Had to swap these for wire grilles on every psu I've had. One day I'll get one with wire already fitted... :duh:
  15. SiMonTiST
    SiMonTiST Minimodder
    14 May 2002
    I've desoldered all the leads for the ATX connector from the PCB of my 200w Shuttle PSU (that's going into my server project) and soldered in all the AT wires and connectors in place of the old ones.
    The project log's in my sig, but it really needs updating (I haven't even confirmed the existance of the PSU yet :eeek: )
    I've still to complete this PSU mod, however. The +3.3v line in the ATX connector isn't required by the AT mobo, so it's not connected to anything at the moment. I'm getting a 2.2 Ohm 7 Watt resistor from Maplin soon, though, to put a 1.5 Amp load on it. I'm also getting a 10 Ohm resistor to put a 0.5 Amp load on the 5V standby line.
    (the reason for all this is because all modern PC power supplies use switching circuitry, instead of big meaty transformers, and therefore every outlet from the PSU has to have a certain amount of load exerted on it, otherwise the PSU can become damaged after long periods of use)
    I'm also going to add 2 0.1uF capacitors (one for the 12v line and another for the 5v line) because the PSU makes some audible high-frequency noise when under load. Hopefully these caps will suppress the noise.
    :dremel:
  16. chopsuwe
    chopsuwe What's a Dremel?
    9 Jul 2002
    Cut out the ugly pressed steel fan gril.
    Cut the side off ready to put plexi on it.
    Lost enthusiasm.
    One year later it's still held together with masking tape.
  17. Dgephri
    Dgephri What's a Dremel?
    9 Sep 2003
    removed all stickers
    sanded down with 80grit and wire brush wheel (for that Machined look)
    replaced 92mm with Quad LED blue fan
    trimmed all molex wires, crimped new pins and plugs on directly at vent slats
    custom run power rails to all components in UV 18AWG wires
    Server style (press in wires) Molex on all rails
    sleeved ATX and 12v Mobo lines
  18. evil_t
    evil_t What's a Dremel?
    30 Sep 2003
    Have an aopen 350w psu. Was noisy as hell. No pics... sorry! :blah:
    Done:
    -Removed cover. I'm using the psu without it.
    -Resoldered all the wires with blue wires.
    -Using 1 rail with 90deg molex plugs
    -Changed the ommagad noisy aopen standard psu fan with a transparent fan@5V
    -Have put the trafo in a little steelbox with one 50mm fan. This is to shield the rest.
    -Added a switch so I can use it to test things.
    To do:
    -Spraypaint the heatsink
    /edit God damn you Leif. Why cant you get out of my text!
  19. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    Done
    - Replaced the Jet Engine with a Panaflo L1A mmmmm...beautiful silence :D
    - Removed stamped fan grill and replaced with a tiny chrome grill
    - Extended the cabling and rerouted it so that its almost invisible
    To Do
    - Cut out a window in the side
    - Remove stamped grate at the bottom and replace with a nice window
    - Paint it black/metallic blue (decide when I get my case lit up)
    - Light in Blue with LEDs (Possibly Red, will decide when I get my case lit up)
    - Fashion a tool for removing the ATX connector using only a pair of nail files and a piece of wood!
    - Sleeve Cabling and replace molexs with UV molex plugs :dremel:
  20. Endre
    Endre What's a Dremel?
    18 Mar 2004
    I don't vare about that kind of mods... the only mod I've done is +3,3v sense line to get 3,8v+@+3,3v. :D
