Graphics How hot should an x800gto run?
Discussion in 'Hardware' started by Shuriken, 3 Nov 2005.
  1. Shuriken
    Shuriken same christmas AV for a whole year
    1 Jan 2003
    As the title says, how hot should my sapphire x800gto run, I've overclocked it to 500 Mhz core and memory, but its 80 - 105 degrees full load! surely thats unhealty, but i cant find documentation anywhere that says what the max operating temperature is.
    Matt
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Erm yea thats WAY too high....
  3. hitman012
    hitman012 Minimodder
    6 May 2005
    Wouldn't worry about it dying at that temperature (GPUs are normally good up to over 120), but it is much too high... I suspect poor contact between the heatsink and core. Try reseating it with some quality thermal paste such as Arctic Silver 5. Also ensure good case airflow, as the fans on GPUs can just keep sucking in the same hot air if there's a deadspot there.
  4. Shuriken
    1 Jan 2003
    thanks, i'll look into that.
    it idles at 60 degrees when not overclocked, is that too high aswell? or am I jsut pushing it too far?
    matt
  5. hitman012
    6 May 2005
    That's too high, really. I don't think you're pushing it too much; I know someone who recently got an HIS one (with the huge AS cooler as stock) and even at 500MHz, its idle temperature is in the mid-30s... you could buy an Arctic Silencer (they are superb, and I'm pretty sure they have one that fits) or alternatively just reset the heatsink with some AS5 :)
  6. AWACS
    AWACS What's a Dremel?
    10 Jun 2005
    I'd say 60 degrees idle at factory settings is much since my x850 xt pe runs at around 50 degrees in idle with the damn reference cooler
  7. Shuriken
    1 Jan 2003
    It hits 80 on stock settings under full load, I'm new to graphics card overclocking and temperatures, but I'm sure thats too high, I'll try re-seating the cooler today.
  8. Shuriken
    1 Jan 2003
    Well that didn't really help, It had quite a thick layer of thermal compound on there, I cleaned that off, put some acrtic alumina on (thats all I had) and the Idle temps lower, but the load temps are slightly higher! Think I'll invest in a decent cooler.
  9. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    I got mine yestaday, currently fully unlocked @ 16p 540mhz core, 560mhz mem, with full load @ 70C , Idles @ 40C. this is on the stock cooler too W00t, It could be your airflow, i got a zalman 7700 (the 120mm fan 1) and 2 120mm fans (intake and outake) + a mesh window.
    -Fr4nk
  10. jamadaia
    jamadaia What's a Dremel?
    18 Jan 2004
    If you want to keep your card from getting borker, honestly dont let the GPU go above 80 - 90 degrees m8 on full load.
    Over 100 is definetly not normal and although may work, will cause irreversable damage.
    If your still unsure, google around on the net and check the max temps of GPUs people have overclocked.
  11. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Thermal paste will take a few days to really start working properly :)
  12. sk8phreak88
    sk8phreak88 Minimodder
    8 Aug 2004
    Just one thing, Are your temps celcious or ferinheight--(Spelling?) Cause for F. That would be really good. But celsious thats another story.
  13. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    Not to jack this thread, but my 6600GT runs about 57-63degree's Idle, and goes into the 70-80's during load. Is that too much? I thought it would be normal, but considering you guys said a much higher card runs at that high and it isnt good..i was just wondering.
  14. jamadaia
    18 Jan 2004
    If memory serves right, the 6x00's run a bit hotter than the ATI x8xx range, but even then I think your on the upper limit there m8. Personally I wouldnt want it running much over 70 myself. But I think your ok with it.
  15. Shadowed_fury
    21 Nov 2003
    DivineSin - Don't think thats too bad, mine idles at 40c with Watercooling, so... :p
