Modding How is this done??
Discussion in 'Modding' started by BojlerTM, 5 Jun 2002.
  1. BojlerTM
    BojlerTM What's a Dremel?
    31 Dec 2001
    Well, becouse I can't read korean, i thougth that some one here would know how tho do this. I am wondering how did the guy in this artice make the clear plexi not so clear? I want just that. The smoked plexi is to dark (well the one I can get), and this is perfect.
    Thanks
  2. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    from the looks of the darkness of the plexi without the lighting, I would have to guess a light auto tint is the way he achieved that. Dont quote though :D
  3. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    Auto tint would be my guess as well. Which just gave me an idea for something new on this tired old case....
  4. BojlerTM
    31 Dec 2001
    auto tint.. thats the film that you put on car windows, right?
    I thought he sprayed somthing on it, but that would be wery uneven..
  5. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    well, i dont think its window tint, i think he used "smoked plexi" you can get it in various degrees of darkness. usually you can get it in grey or bronze, looks like he used the grey kind.
  6. mugsy
    mugsy What's a Dremel?
    3 Jun 2002
    tint
    I agree its not tinting film its colored plexi. Much more expensive, but as you can see the finished result is very cool!
  7. sobriquet
    sobriquet What's a Dremel?
    4 Jan 2002
    no, it's not tinted plexi, because some of the pictures from his progress show it to be quite clear (and colorless!)...it looks like he used those cans of stuff to tint it
  8. kanuslupus
    kanuslupus Minimodder
    10 Mar 2002
    Some of the pictures look like clear plexi though.
  9. UnLoadeD
    2 Jan 2002
    to me it looks like the inside frame is made of clear plexi and the outside shell is grey smoked plexi. if only we had a korean translator 8/
  10. Jordanis3r
    Jordanis3r Jigsaw Master
    8 Jan 2002
    drop him/her a mail---but i am pretty sure it is tinted perspex which was bought like that--otherwise it would have shown piccies of him colouring the plastic ;)
    You can buy it in the uk too--
    displaydevelopments.co.uk
  11. cheekymonkey
    cheekymonkey What's a Dremel?
    5 Jun 2002
    Mmmm
    Either the guy used clear plexi as a rough guide then tinted to do the final peice or . . . .
    . . .is that some kind of spray (tint maybe) in the 3rd picture down with all the tools he used?!
    :dude:
  12. macroman
    macroman The One
    3 Sep 2001
  13. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    that brings up a question I have had and haven't had a chance to expierement yet...
    what if you paint or tint the inside panel of plexi and need to glue it to another piece (in my case at a 90 degree angle). To me, technically, you are actually bonding to the tint or the paint not the plexi and run the risk of it not being secure. Another fear I have is the glue eating up the paint and/or tint...
