Kill this, PLEASE - n00b thread
Discussion in 'Hardware' started by Guest-44638, 15 Oct 2018.
  1. Guest-44638
    Guest-44638 Guest
  2. RedFlames
    23 Apr 2009
    Drivers?
  3. RedFlames
    23 Apr 2009
    You've not disabled them in the BIOS/UEFI by mistake?
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Check device manager for any red/yellow exclamation marks.
  5. Vault-Tec
    30 Aug 2015
    It's perfectly plausible. There will be a controller chip that hooks them into the PCIE on the board. If the controller chip dies so do the things on the end of it. I've heard of sound cards or NIC dying but not usually both. Check the capacitors around where the chips are, and look for any burning on small chips in close proximity.
  6. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Could be a component within the PCH is failing. This would handle Ethernet and Audio among other I/O functions.
  7. Ice Tea
    Ice Tea Minimodder
    26 Jul 2009
    Are you booting with Windows or Linux?
    Try Ubuntu Live disk?
  8. Gareth Halfacree
    4 Dec 2007
    Before mess-arsing around with that, why not do as @Ice Tea says and boot into Ubuntu from a USB stick? If the sound works there, you know your hardware's fine and can mess around trying to fix Windows at your leisure; if it doesn't, then your hardware's chuffed.
  9. Sentinel-R1
    13 Oct 2010
    If it isn't hardware, I'd be extremely surprised. Have you tested every USB port/header, both internal and external? They're also controlled by the PCH so any errors there would confirm hardware.
  10. Gareth Halfacree
    4 Dec 2007
    't'ain't hard: make an Ubuntu live USB, reboot your computer, wait for Ubuntu to load, see if you hear the drum sounds on startup and whether you can load YouTube in Firefox. If you can, Windows is shagged and your hardware is fine.
    Yeah, you're gonna need access to a system with a 'net connection to make the USB stick - which could be a problem if that's your only PC and you're posting from a phone or tablet. Could also go to the nearest newsagent and pick up a Linux magazine with cover-mount DVD, I guess...
    Arboreal and Guest-44638 like this.
  11. Vault-Tec
    30 Aug 2015
    Do you really hate AMD that much?
  12. Gareth Halfacree
    4 Dec 2007
    You could do all that on mine, and it's a five-year-old AMD A10-5800K with no discrete GPU. Hell, I do do all that, except play WoW.
    Arboreal likes this.
  13. Sentinel-R1
    13 Oct 2010
    Yep! Like Gareth said mate, it's really simple and as all basic drivers are built into Ubuntu, no sound or no network = hardware issue.
  14. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    All working? Welcome to Windows, enjoy your stay.
    Sentinel-R1 likes this.
  15. Vault-Tec
    30 Aug 2015
    Sounds like you lost a (soft) PCI bridge. Glad to hear it's OK :)
