Cooling How long can thermal tape last?
Discussion in 'Hardware' started by DAE_JA_VOO, 7 Jun 2007.
  1. DAE_JA_VOO
    DAE_JA_VOO What's a Dremel?
    11 Nov 2005
    What's up guys.
    okay here's my predicament. I've been busy with a mod since January last year. Everything is watercooled. I'm almost done, but now i'm a bit concerned about something. The machine hasn't been powered on for a few months, and i'm a bit worried that the thermal tape holding the RAM sinks on the video cards isn't going to hold. I stuck those RAM sinks on about 3 months ago, maybe more.
    Will the thermal tape hold?
    Thanks guys :)
  2. geek1017
    geek1017 What's a Dremel?
    6 Aug 2002
    So you used thermal paste, not thermal adhesive, to put RAM sinks on your vid card?
    Have they fallen off yet? If not then I'd say you're probably good to go.
    If you do want to re-do it, and you don't have any two-part thermal adhesive, just put a spot of superglue in two opposite corners of the sink. Should work.
    Be careful though as this makes the sinks rather permanent.
  3. DAE_JA_VOO
    11 Nov 2005
    WHOOPS!!!!
    That's my mistake, i meant thermal TAPE. Not thermal PASTE. My bad. Let me just edit my first post.
  4. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Well have feel of them, if they seem rock solidly stuck then I doubt they'll fall off any time soon. Usually thermal tape, like a lot of tapes, loses it's adhesion after its been pulled off, so they should be fine unless you've taken them off, then put them back on (with the same tape)...
  5. DAE_JA_VOO
    11 Nov 2005
    Thanks Frank.
    Unfortunately i CAN'T feel them. The cards are "hidden" in the mod, and it'll take me a day to get to them, which is why i'm asking ;)
  6. Amon
    Amon inch-perfect
    1 Jun 2007
    If you used your system regularly for a week after installing the ramsinks, the adhesion process should be complete.
  7. DAE_JA_VOO
    11 Nov 2005
    Okay but BEFORE that week? Would there be a chance of those heat sinks coming off?
  8. Amon
    Amon inch-perfect
    1 Jun 2007
    Hmm, I'd think not. The Zalman ZM-RHS1 aluminum VGA ramsinks that I just installed attached to the chips very firmly. I'm guessing you used similar quality ramsinks as well, so there's no chance that they'd fall off, even after several months in hiatus.
  9. DAE_JA_VOO
    11 Nov 2005
    Great stuff.
    Thanks Amon :)
