Build Advice How long to run prime 95
Discussion in 'Hardware' started by CrapBag, 29 Mar 2014.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    How long would be long enough to test a 6 core amd cpu/mobo/ram combo?
    I've had it running for 3 hours so far in a mixed test.
    This at stock cpu speeds with 1600mhz ram.
  2. GeorgeK
    18 Sep 2010
    I'd say that was more than enough - I've read in some places that you should leave it for 24 hours or something ridiculous like that but in my experience if you're going to have issues it'll be fairly soon after starting the run. In terms of things levelling out temperature-wise 30 mins or so should be fine
  3. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Usually I bomb before test three. I wouldn't leave it more than 30 mins it's not good for the power circuitry.
  4. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Hmm, I think I'll stop it then.
    Temps on it at full load seem to be awesome though, only 36c under a gelid tranquillo.
  5. GeorgeK
    18 Sep 2010
    That certainly is good :)
  6. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Idle temp is 15c and I'm sure it must be more than that for ambient so maybe a little off :), mind you it does feel cold in here and we don't have the heating on.
  7. Guest-44432
    Guest-44432 Guest
  8. AlienwareAndy
    7 Dec 2009
    LinX works quite well too :)
  9. Pete J
    Pete J Employed scum
    28 Sep 2009
    Honestly, it's up to you. Leave it for as long as you would normally use your computer. If you tend to game in three hour sessions, then three hours is enough.
    I tend to go for 12 hours, then up the CPU voltage a little to guarantee stability. However, a three hour test gets pretty damn close to the stability required for that, so I only have to do two or three of them. Play a movie and use your computer normally (except gaming!) while you're sat at it just to push it a bit harder.
  10. Guest-16
    Guest-16 Guest
