Planning How much do I need?
Discussion in 'Modding' started by disturbed13, 11 Jun 2010.
how much
  1. 1 700ml bottle
    0 vote(s)
    0.0%
  2. 2 700ml bottle
    2 vote(s)
    40.0%
  3. 3 700ml bottle
    3 vote(s)
    60.0%
  1. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    how much liquid coolant do i need for my loop?
    how do you know?
    i have a koolance 80mm res
    im cooling the NB/SB and CPU with 140.1 and a 120.3 rad
    every bit of advise helps
    thanks guys
  2. disturbed13
    28 Nov 2008
    wold 2 be good for playing it safe?
    more
    less
    anyone?
  3. Langer
    Langer Jesse Lang
    24 Jan 2004
    Get extra, never hurts. Plus you'll have to change the coolant eventually anyway.
  4. *brian*
    *brian* What's a Dremel?
    23 Jul 2010
    I used half a litre for my loop with 5.25" drive bay reservoir, 120mm rad, cpu + chipset blocks and using 8mm tubing. But as has been said, better to have too much, plus you'll need to renew your coolant at some point (not sure how often you should?) or have some left for another project!
