How much do you spend on a motherboard?
Discussion in 'Hardware' started by Guest-16, 25 Jan 2008.
  1. £221+
    11 vote(s)
    3.7%
  2. £161-£220
    25 vote(s)
    8.4%
  3. £121-160
    51 vote(s)
    17.1%
  4. £81-120
    124 vote(s)
    41.6%
  5. £41-80
    84 vote(s)
    28.2%
  6. £40 and Under
    3 vote(s)
    1.0%
  1. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I am willing to spend up to 160 for a good motherboard.
  2. haggisathome
    haggisathome What's a Dremel?
    1 Oct 2003
    i would spend as much as it takes to get the best mobo ...... but it would be nice if more emphasis was given to amd , instead of the Intel this Intel that . some of us have not given up on amd ...... (yet)
  3. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    What RAID card are you using? How does it perform?
  4. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    It's this card (price gone up a bit since i got it though :( )
    Compared drive is a single 500GB drive... though it's a seagate .9 whilst the array has .10 drives in it, not sure how relevant that is
    Seems very nice so far, better driver support and stability compared to the onboard nvidia raid i was using, and also i don't have to worry about a drive dying whilst not loosing much space to redundancy :)
    Definately worth the money so far.
    Only problem i do have though is not having any HDD activity lights... i'll sort that out when i'm next near a Maplins :)
  5. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Excellent, I am planning on getting the 2320 at some point. Although I hope I can get it cheaper as the cheapest here is $619NZD or about 240 quid. Its £190 on Scan, hmm, how much do you think international shipping would be? And how to get around customs?
    Best thing is, I will be upgrading soon and will have a spare mobo with a x4 slot on it :D
    The motherboard was $300 (£120) when I bought it.
  6. talladega
    talladega I'm Squidward
    18 Aug 2007
    the one im going to get after I return/sell the one I have now will be $235. the one i have now was $170. so im going for a more expensive one. but with the more expensive one it has newer tech so upgrading the mobo wont have to happen as soon.
  7. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    the motherboard i want to buy (soon) is the ip35 which converted is 138 pounds but thats a bit much for me so im more likly to go with the gigiabyte p35 ds3r which converted is 83 pounds
  8. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    I just recently bought a Gigabyte GA-P35-DS3L for around $100, and I can't even begin to imagine what I would gain from a more expensive board. This thing is absolutely flawless - no corners have been cut, it has overclocking potential, non-electrolytic capacitors, high-quality onboard audio, gigabit LAN, 1333 FSB and 1033 RAM support. The only thing missing is dual PCIe, if that's important to you. I suppose I can see a few advantages to the pricier DS3R in some situations, with more SATA and USB ports, and a better chipset cooler. So, £70 is the most I could ever imagine spending.
    Seriously, if I'm missing something, please tell me what you get for your extra money. I can't even begin to imagine what it might be.
  9. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    I go for motherboards with PWM and solid caps. I bought a Abit p35 pro lat week for a friend (thnx to bitech board of the year award. And its a impresive motherboard. Rock solid.
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Me too, for under £55 so "Rip-off Britain" ain't too rippy. ;)
    It's easy to see what you get for more money with that particular model, as (like a lot of big-brand boards) it's part of a family with a common or related chipset base. But not everybody needs the extras of the higher end boards - Raid, twin PCI-Express x16 slots, more than four SATA, more USB2, DDR3 slots, etc. I decided I didn't. But reviews of the higher end members of a family, read carefully, should give a good guide as to how the junior members can be expected to perform. It would be useful for reviews to point out the range, where applicable, and what you get/lose for more/less money.
    I usually start with the best bang-for-buck processor range, which decides the socket, then look for the best-liked chipset, which narrows things down a lot. Then I can start looking at prices and what you get for your money, and start looking for reviews and user comments on the shortlist. WFM. :)
  11. completemadness
    completemadness What's a Dremel?
    11 May 2007
    Id say ive been spending £121-160 on my main rig's motherboards, i would rather be paying £80-120 though
    I dont know if cheaper mobo's are cheaper cos u cant OC as much, or because they have less features
    But 6+ SATA ports (probably 4 on budget boards) on any board would be good, with an IDE and Floppy
  12. Poisonous
    Poisonous Incestuious
    18 Apr 2007
    Cost isn't really an issue. As long as the motherboard has all the features I need, then I'll buy it.
  13. docodine
    docodine killed a guy once
    10 Feb 2007
    My last motherboard purchase was an MSI P35 Platinum for $100 after a rebate. That's around £50 according to Google. It works perfectly fine, much easier than my previous install.
    The one that I bought before that was a low end micro-ATX Asus running an Intel Celeron... Horrible layout for the Foxconn case that I used. It cost $40 at the time, £20 according to Google.
  14. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Mostly I would want to spend more than $200 (~£136) on a motherboard. Even then it must come with a lot of bells and whistles.
  15. PhenomRed
    PhenomRed What's a Dremel?
    3 Dec 2007
    passive cooling on the motherboard wasn't a big thing for me, my pc currently has about 9 fans in there, i can hear it through the wall in the next room quite easily, so having an extra fan isn't a big deal
  16. Havok154
    Havok154 What's a Dremel?
    20 Aug 2006
    I'm using a P5B-E. It was fairly cheap (~$120) when I bought it and overclocks great. I'll usually get a board that's mid-range with good OC'ing ability. The best is nice, but I don't find enough value to spend the extra dough.
  17. Woodstock
    10 Sep 2006
    whats is cut from the l version (compared to r) other then raid?
  18. crazybob
    21 Oct 2004
    Very little of substance - the L has half as many SATA and rear USB ports, has no onboard RAID controller, and has a smaller, non-heatpiped chipset cooler. It's also missing the two DDR3 slots found on the R.
  19. Woodstock
    10 Sep 2006
    i may end up going with that then
  20. crazybob
    21 Oct 2004
    I'd encourage it. This is by far the best motherboard I've ever owned, and I haven't been able to find a single thing to complain about. That's why I'm saying I can't understand spending more than $100 on a motherboard - if $100 gets you 90% of the features available on a $200 motherboard, and the missing 10% are unnecessary features anyway, there's no reason to spend more.
