Modding How much money do you put into a mod?
Discussion in 'Modding' started by Morphious, 7 Jul 2004.
  1. Morphious
    Morphious What's a Dremel?
    19 Jan 2004
    On average, how much money do you think you spend on any of the mods you've done for your computer?
    And I mean like, new cases and stuff - not small things like putting some rubber feeties on it or something. :p
  2. Firehed
    15 Feb 2004
    Depends. In reality, what it takes but as little as possible. I can also get some stuff sponsored or at least discounted so not a HUGE amount.
  3. WaZzUp115
    WaZzUp115 What's a Dremel?
    12 Feb 2004
    as little of possible... and as much as necessary... :p
    now iwe spent 200$+ or maybe 300$+ ... and i havent gotten far at all.. much because iwe repainted my old case like 5 times and then bought a new case.. and now bought paint that sucked.. and also 2 fans.. like 8$ each..
    new cpu fan for 38$ and GPU cooling for 16$... new PSU for 32$... something like that.. and i still need a new PSU for 110$, a new mobo for 90$, and 4 new fans for a total of 50$ and a radeon x800... plus new paint.. One spray can is 6$...
    :sigh:
  4. omicron
    omicron Baud.
    8 May 2004
    It's always either too much or too little, depending on who's talking ;)
  5. r3Q
    r3Q Minimodder
    31 Jul 2002
    seriously depends on the person. somone like you and me (who prolly has a low budget :duh: ) can and will find "original" ways to make thigs less expensive... those are more like ghetto mods ;)
    but people like zapwizard, piloux, mashie, gnome, and that one guy who spent like 10,000 on his Heavy Metal case (http://www.badgerpackaging.com/heavymetal/) have the money to do somthing great. once and a while- when you got the cash to burn (i will SOON i hope! :worried: ) you can spend some cash. but remember. a mod is not a PSU upgrade, its not plopping a new fan in an old ones spot- or dropping watercooling in a computer.
    a mod is somthing you do to alter the origional look, or mechanics of whatever you bought to make it more to your liking or taste.
    whatever you do, just make it cool for yourself! :thumb: :hip:
  6. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Project divergence cost over 550 to build with the displays and the screen.
    I think you can do a decient mod for 200 US dollars including paint and materials. The bigger the project the more it costs to do.
    My budget for convergence is, well more than divergence...
    Yes it does take money to do something great...
    Project Divergence... 550 dollars to make a 40 dollar case to this... :D
  7. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    Butt loads!
    :sigh:
  8. Firehed
    15 Feb 2004
    My next mod will involve a small fortune in little PSU plugs alone... those low-profile plugs at a buck a piece! Then some modders mesh, w/c parts, the starting case (looking at a v2000, that won't come cheap!!), ps1 screen, and then a couple things. If I had a dollar for each idea, I'd be able to afford it.
    my58vw, divergence was awesome! real eye-catcher, especially with the top-load dvd and front LCD. if convergence has a bigger budget, I'm probably going to crap myself when I see the finished product...
  9. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    what i try to do is buy small things at a time. i dont try to go full out and blow as many paychecks as possible. today i just spent 30 bucks and got 6 cathodes and a 3pin rpm wire. that will be all till next week. what id do is space it out so u can see the price at different amounts and not all at once. sigh i bet all modders wallets cry sometimes...
  10. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    My mod is using fairly common and easily obtained parts, such as PVC pipe, sheet metal and cheap supplies like bondo and spray paint for the bulk of the work. I'll add in a few extension cables of various types, but I already own most of them. You can mod on a budget easily, just have to be creative with your designs.
    My wife gets pissy at me because I refuse to throw stuff she see's as junk away. I look at it as spare parts and potential mods. Don't ever turn down free computers, no matter how old. They always have odd things like cables, sheet metal, LED's, etc.
    For you young pups that may not already have the tools it can be expensive at first.
    Im looking at no more than $100 bucks total in my mod, and its going to be a complete system mod.
  11. splinter_cell
    splinter_cell What's a Dremel?
    8 Sep 2003
    in total i have spent somewhere around 1500 dollars on my ocmputer, spread out over several months, and this includes parts also. its the little things that add up after a while,6 green led fans 2 cold cathodes, 30 leds, paint, sandpaper, sanding block, eyeprotection, dremel, coffee. all things i had to buy so for that its ben about 250-300$
  12. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    My Case has cost over $1200 That doesn't include computer parts either. The line gets a little fuzzy though as when I started this project I had virtually no tools and those things aren't cheap
  13. Axly
    Axly slo-mo...dder
    7 Nov 2003
    total so far.. hmm
    building case from scratch, so..
    Aluminium sheet (1,2m x 2,2m 2mm thick) 25 euro / us$32 something.
    Heatercore, free
    Heatercore no.2, free
    Waterhose, free
    Copper pipes and all sorts of metal stuff, free
    Copper block material, free
    Filter material, free
    Cables, cables, cables.. free
    really cool fan, free
    If you're on a tight budget, or just decide to make everything yourself.. You can find a lot of stuff for basically nothing. Recycling stations, scrapheaps, maybe you know someone who works with something where you can get freebies. Look around ;)
    I'm lucky enough to have access to most kinds of tools, and including everything (paint, material, cables, complete water cooling, everything..) apart from computer hardware, I'm pretty sure I won't pass 1500 Swedish kronor which is about $200.
  14. Hekke1664
    Hekke1664 What's a Dremel?
    30 Mar 2004
    yesterday I spent abou 400€ on watercooling and modding supplies (plexi, leds, ... ) No pc hardware.
  15. Goldfish
    Goldfish What's a Dremel?
    4 Jul 2004
    Well, so far, my "mods" are simple and just adding onto a case. I usually spend about £20 a go with those little mods.
    But with a new project I'll have to budget it, and so far even without the hardware its coming up to around £200 (so, just for the case itself).
    *hopes to get a job soon* :D
  16. Nexxo
    23 Oct 2001
    Too much. :grr:
    Still, perfection costs... :sigh:
  17. f U z ! o N
    1 Feb 2004
    yep. if you want that 5 star rating in these forums it takes alot of money and patience.
  18. ErictheHank
    ErictheHank What's a Dremel?
    28 Jan 2004
    I would say that with the two mods that I have so far (simple, crap mods by bit-tech standards) I spent as much on tools as I did on the materials etc. If only I had access to a decently stocked workshop. I guess I'll have to build it myself. :sigh:
  19. MrBurritoMan
    MrBurritoMan What's a Dremel?
    27 Jun 2004
    i like to recycle parts a little more than buy new ones so i would say a basic case mode fore me would be about $200-300US. :D
  20. Vazzini42
    Vazzini42 What's a Dremel?
    16 Apr 2004
    I have been trying to get good deals on everything I get for my current mod and I really don't wanna think how much it has been total so far, but if I had to guess close to $600 US so far and thats without the main computer parts (mobo, proc, ram, pow supp, HDs)
    UGH ! you made me think about it !
    damn
    Vazz
