Modding How much spray paint do you need for a case
Discussion in 'Modding' started by Moyo2k, 17 Dec 2009.
  1. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Title says it all, wanna respray the interior of my CM 690, I'm ignoring clear coat and primer, just how much do I need to cover it with a decent layer
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    A can of paint normally covers a couple of square meters, so it depends on how much you need to paint, but count on around 5 layers to get a good finish, and some resistance against wear and tear. I would buy 2 cans, maybe a third if you want to be on the safe side.
    Just remember, THIN LAYERS! I have ruined the same case a couple of times because I sprayed too much paint on, and it began to run.. And then its back to the sander. Which is, after 3 times, BOLLOCKS. :p
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Make sure to read the instruction on the can if you're doing multiple layers, every manufacture has different dry/recoat times
  4. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    1. Make sure you use a automotive grade paint like those ones from Duplicolor or House of Kolor.
    2. A 11oz can is usually enough for most work.
