How much to charge
Discussion in 'General' started by jamesdta, 23 Apr 2005.
  1. jamesdta
    jamesdta What's a Dremel?
    19 Jun 2004
    i have a question.
    how much would you charge to bulid a computer for someonr?
    would you charg a flat rate or by hour
    its just a basic computer (no watercooling this time :waah: )
    htanks
  2. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    just add commission to the total cost for labour.. like 10-20% or something
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I've always just added a flat sum, deppendent on who I'm building for.
    You need to decide whats a fair amount.
  4. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    I'd say fixed rate for building a PC. Also, make it reasonable but not too cheap, cause if they think they can get everything dirt cheap they'll take advantage. :thumb:
  5. Redwolf
    Redwolf Supermodel
    7 Apr 2005
    most techs I know charge $150 to $200 just to put it together, you have to charge more if you have to go buy the parts.
  6. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    Hmmm, I charge for the components but in addittion to that I have a builders fee which is a variable, means tested, flat rate (being the little socialist I am those who can afford it pay those that can't trade). For people who have jobs/can afford it I usually charge a fee of between £50 and £75 for a basic build and software install (the more software the higher the charge).
    For mates/family it depends on what they can afford, if its a £200 bog standard special then a case of beer/a couple of bottles of good wine/computer spares/service of some kind (usually a trip somewhere) is the usual payment. If it's £400-600 worth of kit then I usually ask for £25-50 again dependant upon how much software they want installed. For a custom build with watercooling (i.e. pre-overclocked gaming rig, fitting of a watercooling kit, etc) I usually charge 10% up to £120 depending on what they want done.
    Hope this helps you :thumb:
  7. advance
    advance What's a Dremel?
    18 Apr 2005
    I've only built a computer for a freind and I did it for free ( he bought the parts), so I can't help you there. If I were to charge, maybe $50 after the parts.
  8. Lithium
    Lithium super spunk
    26 Jul 2002
    hum hum.....We have. :naughty:
  9. jamesdta
    19 Jun 2004
    thanks
  10. RTT
    RTT #parp
    12 Mar 2001
    £100 is what I ask.
  11. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    i'd ask for £20 for anybody that is nobody to me, or i'd do it for a pint for friends. I dont know how people could charge £100 for building a computer... id feel way guilty (since it really, basically is just buying the right components, and putting stuff in whichever hole it will fit).
  12. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    People manage to get stuff for free atm... Have built a few, re-installed and adviced on a fair few without payment.
    Will start asking soon, as doing stuff for others means you're tech support if stuff goes wrong.
  13. the1maxim
    the1maxim What's a Dremel?
    19 Apr 2005
    I usually charge $50 for the build, or $80 if I'm loading it up with an OS + other software and tweaking it. Loading XP and updating takes a while.
  14. RTT
    RTT #parp
    12 Mar 2001
    Firstly it is a risk - you're asking me to handle sensitive electronic stuff that isn't cheap. If i break it, i'm gonna have to replace it out of my own pocket. Second, you're paying for someone's knowledge of what works together. Putting it together is 1/5th of the work, IMO.
    Close friends / Family obviously not £100, but for friend of a friend, or whatever, sure - £100 please, and it'll usually work out cheaper than PC World, or a better spec for the same price.
  15. the1maxim
    19 Apr 2005
    Get an RMA...lol. Then creatively delay delivery.
  16. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    20-30% of the price of the parts is what I would do, but you could decide to do like a flat $100-$200 for building. Charge by the hour, probably $50-$70 for repair and service ;)
  17. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    i charge 100$ to build a system 200$ if i have to get parts myself. and just for repair and such its 40$ an hour and i come to you.
  18. |3|ackAc|D
    |3|ackAc|D What's a Dremel?
    11 Apr 2005
    to build a system, i charge 200$ flat. but they buy the parts and what not. so far iv done like 20 computer's for people.. word of mouth gets around fast
  19. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    If anyone asked me to, I'd charge £50
    <A88>
  20. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    i tend to charge 10% to 15% of the cost for parts depending of how much they can afford and how many other things i have to do with my time.
