Build Advice How much to save for Haswell?
Discussion in 'Hardware' started by GeorgeK, 2 Apr 2013.
  1. GeorgeK
    18 Sep 2010
    When Haswell drops in a few months, I'll be upgrading my main rig and donating a fair amount of it to the GF. Having been watching out for bargains on here and on the main sites I've actually got everything I need for the upgrade except for the bits that haven't been released yet (CPU & motherboard)
    My main question (hopefully) is a simple one - how much money should I be aiming to put aside for a 4670k and a decent motherboard that will support SLI, SATA 6Gbps, 16GB DDR3 (2x8GB) and USB 3.0? My thoughts based on current prices for Ivy are about £300 - £350. Does this sound about right?
    Thanks in advance!
    George
  2. Kodongo
    Kodongo What's a Dremel?
    29 Feb 2012
    My estimates would be:
    i5-4670k (£180)
    Mobo (£100-£120)
    16GB (£50-£70)
    So your £350 estimate looks about right.
    GeorgeK likes this.
  3. heir flick
    heir flick Minimodder
    2 Feb 2007
    only a guess but i can see it being about £30 to £50 more expensive than ivy, no other reason than intel can charge more and proberly will
    GeorgeK likes this.
  4. rollo
    rollo Modder
    16 May 2008
    Id be closer to £400 if it was me guessing. Estimates put the 4770k at £300. Intel may try and charge £220-£250 for the 4670k ( which is a 4770k - hyperthreading)
    GeorgeK likes this.
  5. Harlequin
    Harlequin Modder
    4 Jun 2004
    can see the i5-4670k being over £200 tbh
    GeorgeK likes this.
  6. GeorgeK
    18 Sep 2010
    Thanks for the suggestions - I've already bought the RAM though, I just need the CPU + Mobo
    Balls... Well I suppose if I keep my budget at £350 and the cpu is at your estimates then I will still have £100-£150 for the mobo...
    Anyone else got any thoughts?
    +rep for the help so far!
  7. Guest-44432
    Guest-44432 Guest
    I'd set aside £400, for the CPU and Mobo. Any change left over can be spent on candy & fizzy pop! :D
    GeorgeK likes this.
  8. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    I agree with the above. If you are looking to avoid disappointment I would budget more around the £450 mark and then at least you may have some spare left over.
    I would say around £400+ sounds a good ballpark figure.
    GeorgeK likes this.
  9. GeorgeK
    18 Sep 2010
    Hmmm - I'd posted this hoping that £350 would be more than enough... Thanks again guys...
  10. rollo
    rollo Modder
    16 May 2008
    Intel has no competition so has no reason to launch at ivy bridge prices, That is the state of the Desktop Consumer pc market right now.
    The pre order prices i have seen had the 4770k above £300 and the 4670k around the £250 mark. Wether these are the prices we will see on launch remains to be seen but it would not come as a huge surprise if that was to be the case.
    With Ivy continuing as its sub £200 chip.
  11. Guest-44432
    Guest-44432 Guest
    I remember the good old days of picking up a Core2Duo 8400 and a decent mobo for well under £200. How times have changed, and prices have doubled! :(
  12. TrevDX
    TrevDX Ah Who Cares Anyway???
    9 Aug 2011
    Is Haswell still due sometime around June/July? I want to rebuild again after dropping the desktop for a laptop but want to get my U2711 maxed out again :D
  13. GeorgeK
    18 Sep 2010
    As far as I know yeah
  14. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    And just think of the increase in performance between a Core2Duo and what came before it - that £200 would have been money well spent, whereas it looks like the comparitive performance increase from the current gen to Haswell will be much smaller!
  15. GeorgeK
    18 Sep 2010
    Money very well spent! I certainly wouldn't be upgrading if I hadn't skipped Sandy & Ivy...
  16. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Think I'll stick with my 2700k a while longer.
  17. Guest-44432
    Guest-44432 Guest
    I agree - Only reason I will upgrade to Haswell-E or IB-E will be for the extra PCI-e bandwidth for running multiple cards. :)
  18. Xir
    Xir Modder
    26 Apr 2006
    Bweh...I was hoping it'd show up sooner.
  19. faugusztin
    11 Aug 2008
    Sorry, but my only reaction to this post can be :wallbash:.
    First of all, last time Intel had a competition was with Lynnfield (Core i5-7xx, Core i7-8xx). Nehalem and anything after that was simply out of reach for AMD, and had no influence on Intel pricing for any quadcore CPU whatsoever for last 2 and half years. There was only a minor price fluctuation in the middle segment (Core i5-2500K vs Core i5-3570K) and zero price change on the top CPU (Core i7-2700K vs Core i7-3770K). Price of i7-4770K will be the same 300-310€ price mark as i7-3770K has; price of i5-4670K will be same as i5-3570K; price of i5-4330 will be similar to the price of i5-3330, the rest of the i5 range packed between these two.
    In short: Intel pricing does not on depend on AMD in enthusiast market for last 4 years now, and on higher mainstream it is detached from AMD pricing for last 2.5-3 years. AMD pricing is relevant only to Celeron/Pentium/Core i3 CPU range, and even in Core i3 range the effect is only minimal.
    Ivy will continue at the prices it has now until Intel stops the production, like it was the situation with any former Intel CPU range. Lynnfield, Nehalem, Sandy Bridge, not even Core 2 Quads and Duos dropped their price in shops when they got replaced by a newer architecture.
    And if one thing you should have learned not to trust in IT market, then it is the preorder prices for unreleased hardware.
  20. davefelcher
    davefelcher What's a Dremel?
    14 Aug 2009
    RAM seems to have shot up in price on Scan. I got 16GB Corsair Vengeance for £70 a while ago; it's now over £100. The 8GB kit is about £15 more now.
