Scratch Build – In Progress How (not) to build a PC case :)
Discussion in 'Project Logs' started by Thomas Riley, 20 Nov 2019.
  1. Thomas Riley
    Thomas Riley What's a Dremel?
    19 Nov 2019
    A special thanks to the following people for their inspiration and help in my endeavor
    bit-tech
    https://www.youtube.com/channel/UCGxtYMx16kD7jK0RKSxsVrw
    Designs By IFR
    https://www.youtube.com/channel/UCV11AccJeiMX4ZyHErV2oPw
    Munkey Mods
    http://smartcomputerstore-com.3dcartstores.com/Munky-Mods_bymfg_19-0-1.html
    Current status
    Assembling and waiting on parts in the mail
    Hello, and welcome.
    I'll be logging my entire process of building a computer case if anyone in the community is interested in how I made / making mine. This is a copy log from my original post on the LTT Forums.
    I'm using 15x15 T Slot aluminum for my frame, Sheet steel for my side panel's and Acrylic for my interior panels, (possibly) tempered glass for my side window.
    The case is designed to have a basement and attic. The intake is on the bottom and the exhaust is on the top.
    I should have around 4,800 watts of cooling capacity
    • 3 liters of coolant
    • 2 reservoirs
    • 2 pumps
    • 30 fans
    • (4) 64mm thick rads (3-480&1-360)-This has now changed to 4 - 480mm rads
    Case dimensions are going to be about 630mmX230mmX1000mm Size is subject to change as I assemble the system.
    Original paint sketch
    Quick model of basement/attic panels made with my phone
    More designs in MS paint.
    More advanced design of the Acrylic basement/ attic panels.
    Finalized design (prototype)
    Assembling the frame- 2 liter for size comparison.
    Adding secondary supports for lower 480mm rad
    Designing motherboard frame supports and working on designing the acrylic motherboard mounting tray.
    Tubing mocked up with soft tubing for proof of concept.
  2. Cheapskate
    13 May 2007
    I swear I've seen this. Have you posted on the Zoo?
    Welcome to Bit. :D
  3. Thomas Riley
    19 Nov 2019
    I'm not familiar with the Zoo, I did originally start this thread on the LTT forums but I moved it over to here as Bit-Tech seems to have more people who are interested in case building/modding.
    I temporary set up my two loops and got some pictures in. I'm currently finalizing my motherboard/ interior case backplate design.
  4. Thomas Riley
    19 Nov 2019
    The motherboard tray is done.
    I'm working on the left and right acrylic panels.
    I should have all three of them finished and cut next week.
