Disaster How not to cut a 80mm fan hole
Discussion in 'Modding' started by lupin, 22 May 2005.
  1. lupin
    lupin What's a Dremel?
    7 Sep 2004
  2. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    only scratches just sand them off and re spray :)
  3. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    Look again, they are deep dents with scratches at the bottom :(
    What did you do? drop a running jigsaw on the case?
  4. Kipman725
    1 Nov 2004
    I think he should cut out a big area ontop of the case then and replace with mesh/acrilic
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    let's hope that was a test piece.
  6. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    o_O what the bloody hell did you use to cut THAT with!? For good cuts in one go, I prefer to just drill a small pilot hole and let my good friend mr. nibbler do the rest ;)
  7. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    he should leave it like that imo, kind of a cool design
    probly use a recipricating saw or something
  8. nick[x1]
    nick[x1] What's a Dremel?
    1 Nov 2004
    Hmm man how did you do that!
    Looks kind of good imo tho :)
  9. mattthegamer463
    26 Nov 2004
    no pic for some reason.
  10. Pointy Burdz
    Pointy Burdz What's a Dremel?
    24 Jul 2004
    I say continue theme to rest of equiptment, or are you trying to reshape into a SHuttle like that Pug advert :)
  11. mattthegamer463
    26 Nov 2004
    whoa now that i can see the pic waht happened!?!?!?
  12. TMM
    TMM Modder
    12 Jan 2004
    lol!
  13. hughwi
    hughwi Minimodder
    23 Dec 2003
    HAHAH! thats one way to do it :D
  14. shroom
    shroom What's a Dremel?
    6 Aug 2003
    Cut the whole bit out, install mesh from the inside with proper hole cut :)
  15. Who_me_33
    Who_me_33 What's a Dremel?
    26 Oct 2004
    Someone is quite persistant. What did you use to make that hole, a shotgun or something similar. Take a look here, someone has used a shotgun to mod a case http://www.2cooltek.com/case001_4.html
  16. Skylined
    Skylined Minimodder
    3 May 2003
    I think that it's harder to do that than doing a clean hole. :lol:
  17. lcdguy
    lcdguy Minimodder
    25 May 2004
    if you want to make some very clean and quick holes use eithe a bi-metal hole saw of, not sure what they call it, but it's a metal/wood hole cutter but i think it's more of a milling bit as all it has is a counterweighted steel rod with a very sharp edge, makes perfect holes, you just have to lubricate it with oil as your cutting it :)
  18. Firehed
    15 Feb 2004
    And I thought my nibbled let-the-fan-grill-cover-the-nasty-edges hole was bad...
  19. Brew
    Brew What's a Dremel?
    8 Apr 2004
    Holy hell
  20. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Riiiiiiiiiiiiiiiiiiight... :eyebrow:
    Why didn't you stop once you realised it was starting to go wrong? :p
    Oh and that's why I cut blowholes from the inside out.
