How often do you change your coolant
Discussion in 'Watercooling' started by pistol_pete, 7 Feb 2014.
  1. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    As per the title really.
    I've had the XSPC Eco coolant in my system for 3 years now, but I can't see any signs of discoloration, etc (it was clear coolant to start with though). The PVC pipes seem in good condition, perhaps a bit stiffer than they used to be and contracted slightly judging by the fact the water level has increased a little since I filled it up in 2011.
    When do you recommend changing it? I've ordered another bottle of coolant anyway.
  2. Big Elf
    23 Apr 2009
    I use distilled water, Benzalkonium Chloride (anti-algae) and have just started using Ethylene Glycol (anti-corrosion) in my loops. I aim to change the water, flush out the loop/change the tubing and clean the CPU block around once a year.
    The tubing may have got stiffer due to the plasticiser leaching out of it and if so there's the possibility that it's gunked up the CPU block. Normally when plasticiser leaches though it makes the tubing cloudy.
  3. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Ahhhhh! (Penny drop moment)
    this is what I've found! Thanks for the explanation. :) Is there any way to prevent this, and any tips of removing said gunk from CPU (and other) blocks?
    Apols for thread hi-jack
  4. Shirty
    Shirty Time travelling rogue Super Moderator
    18 Apr 1982
    I don't WC any more, but when I did I never changed the coolant in 6 years and it was in tip top condition when I disassembled it.
    The coolant? Zalman ZM-G200, hardy the most celebrated concoction in the enthusiast world but it worked a treat in my loop, even through various block changes.
  5. Big Elf
    23 Apr 2009
    The best way to be sure the gunk is removed from the CPU block is to dismantle it and scrub it off with a toothbrush.
    There is a product called Sysclean that can be used if the whole loop is badly gunked up but it's a very aggressive lime scale remover and not intended to stay on the loop for more than an hour. Primochill released this product following numerous complaints after they released a bad batch of tubing.
    There's inconclusive evidence to suggest that water temps in the loop above 30-35ºC increase the rate of plasticiser release.
    Primochill market 'Advanced LRT' as containing less plasticiser and less prone to clouding up, however it is stiffer than other tubing. Although I have some of the Advanced LRT tubing I've not used it yet. There is Tygon tubing that doesn't contain plasticiser but I can't remember the product number but it is expensive.
  6. Tattysnuc
    19 Jul 2009
    Many thanks for the advice - I can;t even leave you rep as you were the last person I +rep'ed when you bought the i7 980 off me :)
  7. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Every 2 years whether it needs it or not for my current rig.
    Copper tube is indeed.....Cheesecake.
    If you dont want plasticizer then consider Norprene tube.
  8. brave758
    brave758 New Member
    16 Apr 2009
    lol when i can see through the water any more... No really, if its still clear its good to go
  9. brave758
    brave758 New Member
    16 Apr 2009
    PS if you want to clean you loop run pinesol through it pine oil is a natural disinfectant and cleaner does a great job.
  10. Big Elf
    23 Apr 2009
    Unfortunately Pinesol isn't available in the UK at a sensible price and I haven't been able to find a similar product.
  11. Nexxo
    Nexxo Stopped treating this country as if it was his own
    23 Oct 2001
    I use Fluorinert, so I never have to change it. :)
  12. true_gamer
    true_gamer Well-Known Member
    4 May 2009
    I usually change it when I upgrade every 6-12 months. I use filtered tap water, and nothing seems to grow in my loop.
  13. B NEGATIVE
    8 Aug 2011
    Who uses Fluorinert?
    Novec 649 is a better,less damaging fluid.
  14. Nexxo
    23 Oct 2001
    Sme Perfluorcarbons are indeed very unkind to plastics, but not all of them are. Fluorinert is inert, so does not react with, thus damage, anything. I've had it in my loop for nearly a decade now, no worries. :)
    Still, Novec 649 is just as good. A little birdie tells me you may be looking to part with these two litres you got there. How much? :D
  15. B NEGATIVE
    8 Aug 2011
    I was thinking more about the environment....
    Pm me about teh fluid?
  16. Nexxo
    23 Oct 2001
    Valid concern. Fluorinert evaporates at room temperature. The data sheet says that it is not harmful to breathe in the vapour, although it advocates working with it in a ventilated area. It does not burn but when exposed to fire the resulting fumes are considered more harmful. Either way I wouldn't want to throw it down the drain (especially not at its cost! :eeek: ).
  17. soxism
    soxism New Member
    11 Apr 2013
    Gezz your Brave. you must have very good quality Tap water where ever you are.
    I Use distilled water + Silver. Been running this build for about 2 years, before that 2-ish years. Never had any problems until last month when i've noticed a massive build up of plasticiser. But i attribute that to the age of the tubing being 3-4 years old, with water running in these for about 2 years.
  18. B NEGATIVE
    8 Aug 2011
    Its not cheap,not wrong there.
    Fluorocarbons kill baby seals tho,I saw it on the internet.........in my Saudi drifters playlist
  19. HawkeSolaris
    HawkeSolaris Member
    20 Jul 2010
    Sorry to hi-jack, but to me the general theme here is to treat your coolant like you treat your teeth- check up on it every 6 months with the dentist? :)
  20. rts2468
    rts2468 New Member
    26 Apr 2014
    I always do a pre-treatment. To flush out all debris in the radiator, reservoir, blocks etc. After that You are safe to use your coolant up to a year before the liquid starts breaking down and looses its ability to hold the transfer of heat from the blocks to the radiators.
