CPU how often do you/should you change your thermal paste on cpu
Discussion in 'Hardware' started by j4mi3, 3 Mar 2012.
  1. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    just wondering because i think my cpu is about 1-2 degrees hotter than when i first installed the cooler
    do you think the paste needs changing? should it be changed at regular intervals for optimum cooling?
  2. wyx087
    15 Aug 2007
    depends on what you are using, but IIRC within 2 years should be fine.
    (please correct me if im wrong)
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Around once a year should do you fine in most instances.
  4. Deders
    Deders Modder
    14 Nov 2010
    Could just be differences in ambient temperature. Weather is getting better now spring is here.
  5. j4mi3
    28 Jun 2011
    true. i wish i had air con in my room :p
  6. hardtailstar
    hardtailstar "insert title here"
    1 Jun 2009
    I usually do mine once a year.
  7. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Depends on how often you upgrade your machine. If you upgrade every couple of years then you should only need to apply it once. Unless you notice your temps go up unusually after X amount of time.
  8. healthhazad
    healthhazad What's a Dremel?
    5 Aug 2011
    As Deders has mentioned, perhaps its just a change in the temperature of the room.
    I've never changed the TIM on my CPU, I figure once its on (if done right) its hardly going anywhere so may as well leave it unless I notice a serious change in temp.
  9. faugusztin
    11 Aug 2008
    Unless we talk about 10C+ difference, there is no point in changing the thermal paste. Do it when you upgrade.
  10. David
    7 Apr 2009
    +1
    Although, I upgrade/reconfigure my rig so often, the TIM gets replaced two or three times a year.
  11. faugusztin
    11 Aug 2008
    Same here :D. CPU usually stays, but boards get swapped way too often :D.
  12. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Mine is only ever changed when I upgrade (12-18 months).
  13. GingerFox
    GingerFox What's a Dremel?
    15 Nov 2009
    This
  14. Dreamslacker
    Dreamslacker Minimodder
    13 Sep 2006
    Nope. Most decent thermal compounds go for years.
    The 1-2'C difference can probably be attributed to the following:
    1) Dust build-up. Dust would obviously reduce the transfer of heat from the heatsink to air.
    2) Fan wear and tear. The fan slows down ever so slightly due to wear and tear and also if it's bogged down by dust (see point 1).
  15. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    When I change my CPU or cooler; there's no need to keep changing it if you get a decent compound.
  16. feathers
    feathers Minimodder
    11 Apr 2009
    Not all pastes need changing even once in 2 years. Some pastes are rated longer. You don't have any dust blocking heatsink fins do you?
  17. j4mi3
    28 Jun 2011
    nah not that i can see. i did give it a quick blow with the air duster a few weeks ago just in case
    its not really a big deal 1-2 degrees il live with. maybe its just warmer these days :p
  18. SirFur
    SirFur PC Gamer and LAzy B0nes
    8 Apr 2009
    I have never changed my TIM paste on any of my rigs.
    Some of mine have run for 7 years non-stop. The only problems I have had is with PSU or with GPU fans; one change of GPU.
    I've never noticed any or negligible difference in cooling temps.
  19. feathers
    feathers Minimodder
    11 Apr 2009
    If I recall the Arctic MX4 i bought is rated at about 5 years or something. I forget.
  20. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    8 years ;)
