Networks How secure is this?
Discussion in 'Hardware' started by crazydeep74, 8 Jun 2006.
  1. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    I want to setup a network as follows.
    Internet --> Netgear FVS318 --> Smoothwall --> My pc
    There are three other computers connected to the netgear. I just want the smoothwall on my PC and file server.
    How secure will I be behind the Netgear hardware firewall and the smoothwall?
  2. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    More secure than with just one or the other, but you are still defenseless against stuff that you accidently download, so keep that in mind, you should still run a software firewall on your computer along with virusscan and a good spyware/adware removal tool.
  3. Glider
    Glider /dev/null
    2 Aug 2005
    A pc is as secure as the person behind it... :) but I ask, why that order? Letting the others go through the smootwall won't harm...
  4. unlimitedsoya
    unlimitedsoya What's a Dremel?
    9 Jun 2006
    You'll be pretty secure as long as you don't download junk.
  5. crazydeep74
    25 Jul 2005
    Well, I dont want programs they use and I dont, to have access through it. So if I just put it on my pc and file server then I can have it very secure.
  6. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    I agree with crazydeep74 here. Having your PC on a separate network than the others helps keep viruses from spreading (or ones similar to the blaster worm anyways.)
    And thats pretty secure. Though, where is your file server? Is it the smoothwall box? Is it on the netgear box? I'd recomend getting a little switch with you, the file server, and the smoothie.
    I'll have to draw up my network diagram sometime :)
  7. simon w
    simon w What's a Dremel?
    3 Nov 2003
    RateMyNetworkDiagram :geek:
  8. Mister_Tad
    27 Dec 2002
    sweet!
    Considering making one of those for a long term project... (10 clusters, 29 storage arrays, 70 firewalls, 42 access points, 3 mainframes, 68 network printers, 104 routers, 546 servers, 143 LAN switches, 33 Voice switches, 4 WAN switches, 2 Tape libraries, 4 optical libraries, 2523 IP phones, 4278 workstations) xD
  9. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    NICE!!!
    Can I come work for you? :)
    I've seen the ratemynetworkdiagram before. Was planning on submitting my diagram once I've drawn it up.
