Modding How they did that!
Discussion in 'Modding' started by ComputerKing, 19 Aug 2007.
  1. ComputerKing
    8 Sep 2006
    hello guys
    I was want to know which tools I need or any one need to make mods like those and how much they cost (the tools) and why to use them.
    future ne[]n
    Black Rain
    Apple Core Duo
    50th Anniversary Stacker
    Ferrari Enzo Tribute
    Cold Fusion
    jokkos case
    or any of this hot mods and case built :geek:
    How the hell the did that! I don't have a clue I saw the logs millions time and I can't get it :blah:
    Thanks very much
  2. radodrill
    radodrill Resident EI
    14 Mar 2006
    Most common tools are:
    Dremel :dremel:
    Drill
    Sander (especially palm sander)
    jigsaw
    scroll saw
    pop-rivet gun
    drill-press
    soldering iron
    heat gun
    clamps :cooldude:
    The list can go on ;)
    Pricing depends on make/quality/type/size of the tools.
  3. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    why don't you read the goddamn logs?
  4. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    It's less of the tools used, but more how there used. ;)
    Any one can have a drill, but not anyone could make the likes of apple core duo without some tallent, motivation/insparation and creativity.
  5. radodrill
    14 Mar 2006
    Ditto; with the right skills you can do complex stuff with simple tools; on the other hand, if you've got no skill the best tools won't help you do S***.
  6. gar
    gar Active Member
    15 Sep 2004
    Yes, practice and patience and perseverance are a must if you are doing a project, decent tools should follow that as you progress IMO.
  7. ComputerKing
    8 Sep 2006
    but they do it very amazing I can't beivle that the dragons made by a:dremel:
  8. radodrill
    14 Mar 2006
    Can be done with a scroll saw; but my guess (just by looking at the pictures) is that he had it laser cut.
  9. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    he used a dremel! he is a god!
  10. ComputerKing
    8 Sep 2006
    mm nice maybe he is :D heheh
    Any ways I think I have to start Save some money and try to gain money or any thing... to buy some tools in future for me :D
    Thanks very much for the help.
  11. Teyber
    Teyber ******
    18 Mar 2007
    here:
    scroll saw
    band saw
    dremel tool
    mitre saw
    table saw
    heat gun
    bending table thingy
    drill press
    a couple of hand drills
    sometimes:
    a lathe
    a mill(or cnc?)
    but those are expensive
    and lots of chemical work for enzo case, et cetera
    ooo and i forgot, a buffing setup(eitehr buffign wheel or wheel set up for a drill)
    and lots of sanders!!!! lots and lots of sanders.
    What tools do you have?
    i recomend first off if you don't have it; a scroll saw and then a drill press. Then a mitre saw or table saw, waht do you gusy think? a table saw cuts perfectly straight lines for panels and such, the mitre and table saws are more common for scratch builds. It depends what kinda modding you want to do
  12. AJB2K3
    AJB2K3 New Member
    12 Dec 2005
    Files AND Needle files
  13. ComputerKing
    8 Sep 2006
    Lol, I will get that too ;)
    Thanks Very much.
  14. TrainedNoob
    TrainedNoob Needs more zipties.
    27 Aug 2007
    If you are working with wood a nice dozuki saw is a welcome addition. I am trying to find one at the moment; not sure where the best place or what brand is the highest quality though.
  15. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    Did I hear, Dozuki? I'm pretty familiar with them, what is your price range? The best that I know of costs around 1500 usd and is entirely hand made but mine are great quality at around 170 usd. What are you planning on using it for? (tenons, dovetails, etc). I know of a few great places to get them if you're interested too.
  16. ssR
    ssR Carbon God
    11 Aug 2006
    i can answer you on the Ferrari enzo mod. Aside from the basic modding tools and power tools that already were mentioned in this thread, i was mostly working with composite materials and it requires more knowledge and experience and less tools. The tools themselves for the basic fiberglass fabrication are very basic, you can see the tools i'm using in some of my video updates. About cold fusion he used laser cutter for most of his parts if i'm not mistaken. Besides, you can always try and PM the creator of a specific mod or ask it in his worklog i'm sure most of the modders will answer you.
  17. ComputerKing
    8 Sep 2006
    Really Nice! But it's kinda how it comes ont perfect, I think like you said the "experience" that not every buddy have it.
    Thanks very much.
  18. TrainedNoob
    27 Aug 2007
    I am interested if you can direct me. I would probably be more into the $170 price range for the moment :cooldude: I will be using it for mortis and tenon joints mainly.
    Oh, and I think a sanding block is a great cheap investment if you want to save your hands. Especially for the things a power sander might be too powerful for.
  19. greensabbath
    19 Apr 2005
    For very good quality saws and very good quality service, misugidesigns.com is really quite good. The woman who runs it, Kayoko is a very nice and knowledgable woman. The saws are also made by Mitsukawa who is still young but very good (you can ask her about them for more info). I have both the cross cut and rip cut versions which are both necessary for making tenons.
  20. Teyber
    Teyber ******
    18 Mar 2007
    A dual action sander, and a mouse sander are great additions, and usualy cheap. Band saws are pretty popular in the uk. Check out a metalcutting band saw also, cuts pretty straight lines
