Electronics How to add eject button on a slot loading BluRay drive?
Discussion in 'Modding' started by trucrymz, 23 Oct 2009.
  1. trucrymz
    trucrymz What's a Dremel?
    26 Sep 2009
    Here's my new (ripped it out of the misses new laptop) slot loading blu-ray drive for my new project which you can find here http://forums.bit-tech.net/showthread.php?p=2122211&posted=1#post2122211
    Anyone familiar with these slot loaders? mine's an Optiarc (Sony/NEC) BC5600S and it does not have an eject button (it was on the laptop's keyboard so I assume its ejected thru software) but does anyone know how I can add a hard eject button?
  2. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    As far as im aware (going by my slot loader) its a case of right click>eject in windows. dont think you can add a physical eject button.
  3. capnPedro
    11 Apr 2007
    Take a peek at the PCB. There might be unused points for a button.
  4. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    ^ This.
    But personally, I'm a bit squeamish about taking apart slim drives, especially slot loaders. Very little tolerance to mess around with. Be careful if you go that route.
  5. Atomic
    Atomic Gerwaff
    6 May 2002
  6. error404
    error404 What's a Dremel?
    11 Oct 2009
  7. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    The slim drive in my Studio does not have any sort of manual eject, but I have yet to look at the pcb.
  8. trucrymz
    26 Sep 2009
  9. Evylrat
    Evylrat What's a Dremel?
    4 Dec 2002
    Anyone managed to open this sucker up? I had a go last night, but over than getting the top cover off, didn't know where to start. I have a doner IDE slot drive with a bezel (kinda fits) and eject / LED indicator PCB I'd like to try and fit, but on both drives just couldn't work out how to safely remove anything.
