Open Source How to add physical drive to VM on exsi 5.0
Discussion in 'Software' started by happysack, 28 Jan 2012.
  1. happysack
    happysack goodateverthinger
    19 Dec 2009
    As above? Anyone know how todo this, as far as I can see I can I ly format the drives onto datastore and them create virtual disks and add them?
    Anyone shed any light!?
    Cheers in advanced
  2. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    What you are trying to do is called an rdm disk. Raw Device Mapping. You should be able to do it from the VM settings. Add new hardware and choose disk. You Have the option of creating a new vmdk disk, using an existing vmdk disk or using a physical disk. The physical disk will need to be unformatted with no partitions at all.
  3. happysack
    19 Dec 2009
    no i wanted to added a physical disk with data already on it :/
    perhaps i wont use ESXI after all :/
  4. saspro
    saspro IT monkey
    23 Apr 2009
    What's your end goal?
  5. faugusztin
    11 Aug 2008
